Thread: Audi 80 project - Pointers
  1. Audi 80 project - Pointers
    Oct 2015
    Just became an owner of a Audi 80 b3. 1.8 Carb.
    Anyway it has a few issues starting off by losing water.....did 70 miles yesterday and it used about half of the water in the tank.......will it be a dreaded head gasket or are these prone to other issues for using water?
    The window wipers also only work on full which is quite annoying.....any tips?
    The engine is quite lumpy but very likely needs a good servicing etc.
    Getting condensation inside the car so will be looking for new seals im guessing for the doors.
    Any advice would be much appericated for these cars as its my first audi let alone first 80.
  2. Re: Audi 80 project - Pointers
    Dec 2007
    8 Post(s)
    Check pollen filter as a possible cause of condensation,also check under carpets for water.
  3. Re: Audi 80 project - Pointers
    1834 Post(s)
    A80, pollen filter..... plenum Chamber..... nooooo. I would rather do ten head gaskets on that car than one on a modern A4......
  4. Re: Audi 80 project - Pointers
    Oct 2015
    Does this mean its likely the head gasket that all my waters disappearing to
  5. Re: Audi 80 project - Pointers
    1834 Post(s)
    Not necessarily, from what you say it could be the heater matrix that is leaking but you would smell it and get steam out of the dash vents.
  1. My '03 Audi Allroad project
    By Chema.RB in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-08-2017, 10:42 AM
  2. Audi 2.5 TDI (AKE) -- project -- more power
    By 011coach in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-10-2016, 08:18 PM
  3. Buying Pointers/Advice
    By Adman in forum Golf MK5 - 2004 - 2009
    Last Post: 18-04-2011, 05:20 PM
  4. Question seat belt 3 pointers
    By drg in forum Golf MK4 - 1999 - 2004
    Last Post: 19-09-2010, 11:31 PM
  5. Question Brake upgrade? Any pointers?
    By fancy a cuppa in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-07-2009, 06:00 PM
