Thread: CAN a6 4f ?
Results 1 to 10 of 14
  1. CAN a6 4f ?
    Sep 2017
    Paris (france)
    Hello
    I can not understand how to find the CAN link on my A6 4F. (2010)
    the color of the wires is orange / green for the top and orange / brown for the Low ? just? ..
    there is a CAN network in the car? ....only one? can I take a connection anywhere?
    it is to connect a video interface that needs a CAN link with the car.
    I thought to take it by dismounting the air conditioning console, but it's too difficult, I do not want to break ... so,
    I found under the glove box, two son wound together (I guess it's the CAN) orange green and orange brown.
    that's it ?
    thank you
    https://img15.hostingpics.net/pics/834828aaa.jpg
    A6 2.7
  2. Re: CAN a6 4f ?
    Oct 2012
    Estonia
    44 Post(s)
    We have few different can networks in the car, depends of your instruction...normally its either dash(infotainment) or convenience can network which is needed...so double check instructions where they advice it to connect!
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+
    Other: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, B/O tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Chrome door handles, Efficiency prog via cluster & gateway flash...
  3. Re: CAN a6 4f ?
    Sep 2017
    Paris (france)
    look, I do not understand !!
    https://img15.hostingpics.net/pics/684469Capture.jpg
    I asked the question at home (seller) but I do not dare to repeat that I do not understand .... their explanation!
    the "barrier" of the language is an additional difficulty (I am French)
    A6 2.7
  4. Re: CAN a6 4f ?
    Oct 2012
    Estonia
    44 Post(s)
    Remove ac, video is prefacelift, but he explains also how to remove it on facelift...if i remember ac runs from convinience can, so you can find gateway and tab those there also...go by color code!
    How to remove Climatronic (AC and climate control buttons) on Audi A6 (C6 4F) - YouTube
    It might be instruction for 2g high regarding color code and a6(i dont know)...elsa will give you 100% answer regarding color code!
  5. Re: CAN a6 4f ?
    Sep 2017
    Paris (france)
    I tried, without any success!
    I found another video in French, it's the same air conditioning
    than mine, on the video he lifts and pulls at him, but at my house
    it's impossible ! I forced like crazy, impossible to disassemble
    Comment enlever le bloc clim sur une Audi A6 C6 _ 4F - YouTube
    A6 2.7
  6. Re: CAN a6 4f ?
    Oct 2012
    Estonia
    44 Post(s)
    in that case extend wires to gateway and tap(properly) them there, to the same color codes as on instructions!
  7. Re: CAN a6 4f ?
    Sep 2017
    Paris (france)
    it's crazy ! it seems very easy, but at home it's impossible!
    I'm doing exactly the same thing ....
    another video
    2005 - 2009 Audi A6 iPod AUX USB Adapter Install Dension GW51MO2 Spec.dock AUDIC6V2i Part 1 of 5 - YouTube
    the two CAN sons I found are behind the glove box, I do not know which gateway number,
    https://img15.hostingpics.net/pics/974452222.jpg
    I will try to find the number of this gateway
    if I can find the number of this gateway then it will be necessary to see if
    does the same circuit as the CAN of air conditioning ...?
    it would have been much easier if there was only one communication CAN for the whole car.
    if it is a CAN, such as air conditioning, then it will be ok, otherwise ... it is absolutely necessary to disassemble this air conditioning.
    A6 2.7
  8. Re: CAN a6 4f ?
    Oct 2012
    Estonia
    44 Post(s)
    gate is the one on pic with audi rings on it(black box)
    http://www.myaudisite.co.uk/Images/M...ps95046ebd.jpg
    BTW: on newer a6 you need to remove vent etc...to get access to release climate panel clips(only pulling climate panel will not help)!
  9. Re: CAN a6 4f ?
    Sep 2017
    Paris (france)
    thank you very much for your help and your participation.
    so "1" is CAN gate for air conditioning ? ( it's not the order of the doors? )
    https://img15.hostingpics.net/pics/36946165AA.jpg
    CAN wire colors are orange / brown and orange / green
    what is "2"? it has the same colors of CAN son orange / brown and orange / green
    the connection documentation of this video interface is wrong at this level
    for CAN wire colors? or .... audi has changed color of CAN wires with the facelift version (mine ... 2010)
    https://img15.hostingpics.net/pics/94842926BB.jpg
    A6 2.7
  10. Re: CAN a6 4f ?
    Sep 2017
    Paris (france)
    after ...xx research, I think it's the gateway " J255 "that manages the air conditioning.
    and the CAN wires would be nice orange / green ... orange / brown ...??
    but can not be found in elsawin? (no tracking?)
    or is he in the car? ... I continue to search
    https://img15.hostingpics.net/pics/1...limatronic.jpg
    A6 2.7
