Thread: Stop/Start Intermittant
Results 1 to 10 of 12
  1. Stop/Start Intermittant
    In the last few days my start/stop on my 2013 1.4 TSI GT has been intermittant. Sometimes it works and most times it doesn't. Only message I get when I select status in the menu is "High Power consumption" or something smilar to that. Anyone else had this and can advise please ?
  2. Re: Stop/Start Intermittant
    I had same before battery gave up. Your battery getting weak. Regular short journeys killing your battery.
    After battery replacement stop start works nearly enough straight away.
    Sent from my SM-G950F using Tapatalk
    1 1 0
  3. Re: Stop/Start Intermittant
    Thats a good call. I have not been using my car much for a few weeks now and then only for short journeys. Makes sense if the battery is not being fully charged that something like stop/start which is a heavy power user would cut out. I'll put it on charge once a week if I stay at the same usage rates. My wifes Yaris has the same issue with short journys and I top her charge up once a week.
  4. Re: Stop/Start Intermittant
    Quite few comments on net about battery not lasting over 3 years on mk7. Charge it, see how it goes. I kept my to the point where i was getting warning "Battery Low" and then replaced it. First signs stop start works occasionally, second sign stop start not working at all and last is low battery warning on start up.
    Batteries not cheap, got mine replaced at quick fit for 170 incl fitting. You will need get car codded after replacement to let it know that new battery fitted.
  5. Re: Stop/Start Intermittant
    Ouch.
    Charge shows as drawing max current so hopefully mine is a low battery. Especially as I say, it has only been used 1-2 times a week for short journeys.
    When you say coded after new battery what does that mean ?
  6. Re: Stop/Start Intermittant
    Basically connect to diagnostic tool and change settings in battery section, input new serial number etc. So system addapts altenator not to overcharge it.
  7. Re: Stop/Start Intermittant
    And theres me thinking you just swap it out....
  8. Re: Stop/Start Intermittant
    You can just swap it but codding it correctly will give max life to new battery
  9. Re: Stop/Start Intermittant
    Makes sense. Thanks again
  10. Re: Stop/Start Intermittant
    Charge was pretty quick to get it up to 13v...2 hours on max charge which is good on a healthy battery. Indicator on my Varta battery is solid black which indicates good. So fingers crossed......
    Edit: Stop/Start is now listed as "available" is car status. So hopefully it was my lack of use that had the battery running at sub optimal level and hence the intermittant nature of the problem. From what I've read the Power Consumption High is a good pointer to that...or of course a duff battery
  1. How does Start/Stop interplay with Stop-Go on the ACC?
    By Timothy Nathan in forum Audi A6 - C7 Forum - 2011-
    Last Post: 09-02-2012, 11:40 AM
  2. Question 2.0 Conv - Intermittant non start
    By JohnnyD99 in forum Golf MK4 - 1999 - 2004
    Last Post: 08-03-2009, 09:11 PM
  3. Intermittant failure to start
    By davebrannigan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-12-2008, 07:12 PM
  4. Please Help Intermittant start problem Mk2 GTI 8V
    By bluejuice in forum Golf MK2 - 1984 - 1992
    Last Post: 23-09-2008, 07:03 PM
  5. Audi A4 non start problems(intermittant)
    By WestgateMotors in forum Chat - Anything with wheels
    Last Post: 02-04-2008, 10:00 PM
