Thread: Error code 00575 intake manifold pressure deviating
  1. Smile Error code 00575 intake manifold pressure deviating
    Nov 2016
    Nelson South Wales
    Hello All, My Old reliable A4 B5 Avant is having a hissy fit. NO boost like limp mode ? The only error is 00575, I have swapped the oil temp water temp all the filters and coolant and oil too. What is the error 00575 pointing too ? I says intake manifold pressure deviating, but not what is doing it. I have checked all the vacuum pipes and fittings and fond NO issues. Could it be one of the boost control solenoids ?. PLEASE help I am missing the Old Lady big time. Thanks Paul
  2. Re: Error code 00575 intake manifold pressure deviating
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by Bahamacharger View Post
    There are some ideas on the Ross Tech Wiki:
    http://wiki.ross-tech.com/wiki/index.php/00575
    Good luck!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  3. Re: Error code 00575 intake manifold pressure deviating
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    yes it could be the n75 solenoid, have you tried sucking on the turbo actuator diaphragm vacuum tube to see if diaphragm is split, could also be MAF sensor. A basic OBDII scanner will not give you much to go on unless you can trend live data etc.
  4. Re: Error code 00575 intake manifold pressure deviating
    Nov 2016
    Nelson South Wales
    I had a Pal call over last night with his Snap on reader from his Job. It came up as My MAF had flat lined. On live data it was not moving at all and the other points were all good to go. I have ordered a new MAF. Thanks Guys's.
    1 1 0
  1. Replies: 28
    Last Post: 20-09-2023, 01:39 PM
  2. Fault 00575 - Manifold Pressure Sensor
    By BadgerBoy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-09-2014, 07:12 AM
  3. A6 2.5 TDI 00575 Inlet manifold pressure exceeded
    By devine0969 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-02-2010, 08:27 PM
  4. 00575 - Intake Manifold Pressure: Control Difference
    By ashforduk in forum VCDS - General Questions
    Last Post: 13-11-2008, 10:25 AM
  5. Replies: 12
    Last Post: 06-10-2008, 08:25 AM
