Thread: CR140 - heater only hot on recirc?!
Results 11 to 20 of 21
  1. Re: CR140 - heater only hot on recirc?!
    Mar 2017
    King's Lynn, Norfolk
    Quote Originally Posted by Renars View Post
    Then maybe something with heater controls themselves?
    It did cross my mind but if you sit the car still for ages it gets warmer until you start driving which points to it being something mechanical.
  2. Re: CR140 - heater only hot on recirc?!
    Mar 2017
    This is bugging me to the point of considering part exchanging the car if I can’t fathom it out soon.
    does anyone have any thought as to what it could be?
    To summarise...
    thermostat is fine, up to 90c within 10 mins or so
    water pump is fine
    aux water pump is fine
    heater matrix flushed
    VCDS shows no faults and HVAC all working
    metal pipes under the dash to the matrix are hot
    rad gets hot
    car never overheats
    coolant looks clean
    header tank was staying cold, VAG specialist found that one of the pipes to the tank had a valve inside that was blocked/broken so has replaced it with a straight pipe for the time being.
    i still only get cold air blowing out. What on earth could it be?
    My only thoughts now are either a blocked matrix that won’t flush out or something electrical that VCDS hasn’t picked up?
    thanks
  3. Re: CR140 - heater only hot on recirc?!
    Jan 2018
    Sussex
    55 Post(s)
    My bet on blocked heater matrix. I think its bypass unit and flush may not work.
  4. Re: CR140 - heater only hot on recirc?!
    Mar 2017
    What do you mean bypass unit? Cheers
  5. Re: CR140 - heater only hot on recirc?!
    Jan 2018
    Sussex
    55 Post(s)
    If it cannot get through it bypases and there is no heat given to air around. Like a safety measure to kerp coolant circulating.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  6. Re: CR140 - heater only hot on recirc?!
    Mar 2017
    Ah I see
    Well, I've just ordered a matrix so lets see if I can get it out without removing the dash..
  7. Re: CR140 - heater only hot on recirc?!
    #17
    Jan 2018
    Sussex
    55 Post(s)
    My 1.6 tdi CAYC golf starts blowing warm air one minute after engine start since it has electric heater like all of them have (at least I think so) I guess 2.0 tdi also have this great feature. But seems yours doesnt work either if it has it.
  8. Re: CR140 - heater only hot on recirc?!
    #18
    Mar 2017
    Tonight I’ve stripped most of it down ready, glovebox out & bits of trim removed in preparation & I can now see the end of the matrix.
    Theres a lot more in the way compared to the mk6 Jetta how to & a different matrix too. I seem to have more electrics around mine.
    if I do have an aux heater then no it’s not working but VCDS isn’t showing any faults.
  9. Re: CR140 - heater only hot on recirc?!
    #19
    Mar 2017
    I have heat!
    Appears to have been the heater matrix.
    very easy to get out.. absolute pig to get the metal matrix pipes into the new matrix. Managed to get one clamp on but the other one just will not seal tight enough to get the clamp round.
    After many hours of swearing at it and pulling muscles (I’m not a contortionist) I’ve given up and booked it into my VAG specialist to fit two new clamps then I can put the interior back together.
    I did however start it up and somehow even without the clamp it doesn’t leak a drop so I did a good 30 mile drive and it was amazing - I was actually hot!
    I am absolutely shattered but seeing the light at the end of the tunnel now I hope.
  10. Re: CR140 - heater only hot on recirc?!
    #20
    Jan 2018
    Sussex
    55 Post(s)
    In the last picture its the electric heater element I guess. Why didnt that work ...
    Current cars:
  1. 2009 2.0 TDI CR140 Problem
    By Jettatdisport in forum Golf MK6 - 2009 - 2013
    Last Post: 05-09-2016, 01:39 PM
  2. recirc air flap
    By passat 130 tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-08-2010, 04:57 PM
  3. Very little cold air blowing - only works on recirc
    By 832ark in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-05-2009, 10:27 AM
  4. CR140 Remap
    By dan_the_v8man in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-02-2009, 05:26 PM
  5. Heated Rear Window & Recirc
    By podwin in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-12-2008, 01:54 PM
