Thread: Parking brake failure issue
  1. Parking brake failure issue
    May 2008
    Incident on Xmas eve happened that i'm still scratching my head on.
    Parked car on a spot i've parked on before, got something out of the boot, locked up and left the car.
    Came back to the car to find it rolled back and into a residents fence with the bumper needing to now be replaced.
    I'm very concerned about this, has anyone had this issue before? I've been searching and found a rather large amount of reports of this happening.
    Where do I stand in terms of liability here? Could the EPB had failed?
  2. Re: Parking brake failure issue
    1840 Post(s)
    What did the button say the status of the system was? Get the system code read, if there is nothing on there, no photographic evidence and the system now working, you will get nowhere.
  3. Re: Parking brake failure issue
    May 2008
    Car still when left, car at bottom of hill when i get back.
    I'm going to be ringing VW by the end of this week.!
  4. Re: Parking brake failure issue
    1840 Post(s)
    What did the parking brake button show when you found it? Does the system work normally now. If it does, I suggest you get the system code read before you let VW see it.
  5. Re: Parking brake failure issue
    Nov 2017
    Cambridgeshire
    10 Post(s)
    It’s always worth leaving the car in-gear to be honest (if it’s a manual) and if parked against the kerb with some lock on. An Insignia up the road had a parking brake fail a few years ago, it went about 100 metres stopping agains the lamppost over the road (and putting it at a 45 degree angle!), there was a known issue on these and from then on he parked facing up the hill with the front wheels turned to the right
    2015 Passat B8 2.0TDi 150 GT Estate in Deep Black
    2005 A2 1.4TDi 75 SE in Silver
  6. Re: Parking brake failure issue
    Dec 2017
    Sweden
    I have a 2015 Passat here in Sweden and yesterday it was in the garage for a recall on the auto handbrake.
    Maybe worth getting it checked out.
  7. Re: Parking brake failure issue
    Apr 2007
    Lancashire
    Have you Googled to see if it's a common fault? If it is, I'd be heading for my dealer and asking for the recall work to be done and a new bumper fitted.
  1. Parking Brake Failure
    By philipharmes in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-02-2020, 11:10 AM
  2. Parking brake failure see owner's manual fault
    By ellectrastar in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-12-2014, 09:30 PM
  3. Parking brake failure!
    By thescouselander in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-10-2012, 10:25 AM
  4. Parking Brake Failure Error in DIS
    By Sheroo in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-05-2011, 09:46 PM
  5. parking brake failure appearing whilst driving
    By beolight in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-04-2007, 08:32 PM
