Thread: Passat b6 BKP engine idle
Results 1 to 10 of 10
  1. Passat b6 BKP engine idle
    Feb 2017
    St Helens
    Good evening.
    I'm still rocking my 2007 Passat b6 (the amazing BKP variant) which has given me many troubled miles...
    Half the engine has being replaced along with brake calipers yet the dam thing likes to shake in idle. I've noticed that with the ac on the shaking stops. I hear that a fix is to increase the idle revs a little but each time I use OBD Eleven and attempt to change it I get
    Function cancelled, marginal conditions not met
    I've read that it may have something to do with it not working on PD variants.
    Any ideas guys?
    Thank you
  2. Re: Passat b6 BKP engine idle
    May 2012
    Everywhere
    308 Post(s)
    Any codes ?
  3. Re: Passat b6 BKP engine idle
    1837 Post(s)
    IF the timing is spot on and IF it has the revised injectors fitted, there was a software update to deal with this so can you find out what your software revision number is?
  4. Re: Passat b6 BKP engine idle
    Feb 2017
    St Helens
    Hi all.
    There are no codes related to the engine running. In regards to the software I will have a look first thing in the morning.
    It was last in a vw dealer back in 2014 for its cam belt. Before this point it was regular in due to it being a fleet car. So I can imagine it's on the latest version?
    Since then it's being to vw specialists.
    Is it possible to change the idle revs using vcds or obd eleven?
    Thanks again
  5. Re: Passat b6 BKP engine idle
    1837 Post(s)
    Some software versions allow the idle speed to be increased by loging in and then in adaptations.
  6. Re: Passat b6 BKP engine idle
    Feb 2017
    St Helens
    Yeah I've tried to but all I get when i attempt to make a change is
    Function cancelled, marginal conditions not met.
    Ive tried to do this with the engine at temp and with the engine on and off. No dice
  7. Re: Passat b6 BKP engine idle
    1837 Post(s)
    What are you using?
  8. Re: Passat b6 BKP engine idle
    Feb 2017
    St Helens
    I'm using obdeleven
  9. Re: Passat b6 BKP engine idle
    1837 Post(s)
    Pro or normal?
  10. Re: Passat b6 BKP engine idle
    Feb 2017
    St Helens
    It's the pro version. Tried it again today and it came up with the same error.
  1. Vw passat 2.0 tdi 8v BMP idle stabilization
    By makdam in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-02-2015, 09:08 AM
  2. Passat, noisy idle
    By STEVO578 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-09-2013, 11:52 PM
  3. Please Help VW Passat Will Not Idle
    By sg70 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-05-2009, 07:11 PM
  4. Passat High Idle.
    By tommyk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-04-2009, 08:34 PM
  5. idle problems on passat
    By curly in forum Passat - Archive Topics
    Last Post: 01-11-2005, 05:35 AM
