Thread: Rear Bumper removal for Towbar fitment e-tron
  1. Rear Bumper removal for Towbar fitment e-tron
    Dec 2009
    Dublin, Ireland
    25 Post(s)
    Hi all
    ASAP in 2018 I need to fit a towbar to my Q7 e-tron. All indications are there is nothing different for the e-tron to normal Q7 tdi. I don't have the panoramic roof which does appear as a factor (no idea why).
    2 options.
    1) Westfalia detachable swan-neck + relay style generic electrics all for £310, I have fitted this style previously to my previous VW Phaeton and it works absolutely fine.
    2) The factory electric retractable kit + electronic interface. A few new-original kits on ebay for about £800. A bit more work to fit the electronics, and probably some re-coding to recognize the interface.
    Can't decide which option, but TBH I do very little towing, just a dingy, small trailer & bike rack: so probably the Westfalia removable swannexk.
    To do it DIY, the information I need is rear bumper removal, and access to wiring loom for turn signals, etc.
    I have done this before so am comfortable with the process, but as new to the Q7, utterly unfamiliar as to how it's put together!! ( which after this exercise, I plan to remain...)
    Regards
    Hugh
    Dublin
  2. Re: Rear Bumper removal for Towbar fitment e-tron
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    PF Jones will supply you the westfalia one which is the one I have fitted to my A6, they come with very detailed instructions. You can also view the fitting instructions on their website, which helps.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  3. Re: Rear Bumper removal for Towbar fitment e-tron
    Dec 2009
    Dublin, Ireland
    25 Post(s)
    Hi all
    I now have the Westafalia hitch delivered ready to install. It all looks straightforward (90min according to Westfalia instructions ), I have installed it before on a previous car so so it should be OK.
    One question only: Bumper removal.
    The supplied instructions skip over this, and the best I can find is this (note it's not a Westfalia hitch)
    This indicates that the painted arch trims must be removed to reveal a hidden torx screw, I assume this is accurate? I am wary of damaging painted trim panels
    However, it's an Audi video, and the external bodywork looks the same as mine (internally mine is e-tron).
    Hugh
    Dublin
  4. Re: Rear Bumper removal for Towbar fitment e-tron
    Mar 2016
    Budapest, Hungary
    39 Post(s)
    According to the Factory Workshop Manual, the first step in the bumper removal is:
    "Remove wheel arch cover (rear) "
    I just looked the rear bumper and for e-tron looks little bit different than the diesel model, but the screws and bolts look the same.
  1. GTD rear bumper fitment
    By busta in forum Golf MK6 - 2009 - 2013
    Last Post: 27-07-2016, 08:54 PM
  2. Towbar wiring rear bumper / bumper valance removal
    By Stu Sheridan in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-10-2015, 11:52 PM
  3. Replies: 0
    Last Post: 16-02-2010, 07:18 PM
  4. Towbar fitment - Bumper cut?
    By jeepster1961 in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 22-08-2008, 04:34 PM
  5. Rear bumper removal for towbar installation
    By makemineamythos in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-09-2007, 07:35 AM
