Thread: abs power supply
  1. abs power supply
    chester
    17 Post(s)
    Got a p1200 abs power supply code,does anyone know where the fuse for this is located/or any idea's what the problem is before I start tearing things out,ta
    A4 B6,A4B7Quattro,MK4 Golf,MK5Golf gone and well forgotten,MK6Golf.
  2. Re: abs power supply
    Jan 2009
    Birmingham
    35 Post(s)
    check fuse f7 and f42 in side panel
  3. Re: abs power supply
    chester
    17 Post(s)
    Thanks arman,both tested ok,all I'm getting is p1200 abs power supply,no steering angle sensor or wheel sensor,beginning to suspect the abs controller,its been stood for 10 days undercover so out of the rain but its been very damp of late,incidently I tested the battery voltage on mine and its 12.4v so yours is a little down but not much
  4. Re: abs power supply
    Jan 2009
    Birmingham
    35 Post(s)
    Yes could be abs controller nev
    Im going to replace my battery at the weekend see if that fixed the supply voltage terminal 30 code last time i changed battery was in 2011 so most likely the current battery is not up to it anymore.
  5. Re: abs power supply
    chester
    17 Post(s)
    Looks like my abs controller has rung in sick I'm getting code no power to abs valves,I've been weighing up the job and its possible to get at the electronic side and split it from the valves side so maybe I can get hold of a secondhand one and change over the module and recode it,saving disconnecting the hydraulic lines and bleeding,has anyone attempted this and is it possible to recode the two halves.
  6. Re: abs power supply
    chester
    17 Post(s)
    Anyone got a wiring diagram for the abs system,Need to know if the abs module has a direct power supply or via a relay.
  1. 12v power supply blowing fuses.
    By DrNorthy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-05-2014, 02:49 PM
  2. A6 power supply in rear?
    By SwissBuster in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-10-2013, 04:16 PM
  3. Power supply in boot
    By gblades in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-07-2011, 08:14 PM
  4. How To Power supply for Sat Nav in T4
    By vwbadger in forum The Commercial Range
    Last Post: 12-09-2010, 08:08 PM
  5. 04 plate t5 onboard power supply
    By MARK68 in forum The Commercial Range
    Last Post: 13-08-2010, 03:53 PM
