Thread: Rear Windows stick under weather seal on opening
  1. Rear Windows stick under weather seal on opening
    May 2007
    Brookfield
    Hi, so had my A7 2 months very happy, but have question about window operation.
    When opening the front doors the windows drop slightly to clear the weather seal, ok all good.
    However when the rear doors are opened the window drops slightly after the door is opened!!
    I did a VCDS sweep when I bought the car I noticed the left rear door had fault 02111 NO or incorrect basic setting'
    the right rear does the same but showed no fault.
    Recent scans show no faults!!!
    Is this normal operation or should the rear window drop before the door opens?
    Cheers DS
    Address 62: Door, Rear Left (J388) Labels: None
    Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
    Component: TSG HL H03 0507
    Revision: -------- Serial number: --------------
    Coding: 010F14024021620002080002
    Shop #: WSC 02391 785 00200
    VCID: 49924F2CE0DF0169F91-801C
    1 Fault Found:
    02111 - Motor for Window Regulator
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Freeze Frame:
    Fault Status: 00100101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 131
    Mileage: 67403 km
    Time Indication: 0
    Date: 2017.08.27
    Time: 15:53:22
    Address 6D: Trunk Elect. (----) Labels: Redir Fail!
    Part No SW: 4G8 959 107 Q HW: 4G8 959 107 F
    Component: HDSG-Modul H13 0043
    Revision: 11013001 Serial number: 281301451
    Coding: 0A3305C002
    ASAM Dataset: EV_HDSGAu573 001022
    ROD: EV_HDSGAu571.rod
    VCID: 438E5D04CAF3DB3933D-8016
    No fault code found.
    Address 72: Door, Rear Right (J389) Labels: None
    Component: TSG HR H03 0507
    If it ain't bust don't fix it!
  2. Re: Rear Windows stick under weather seal on opening
    Mar 2008
    11 Post(s)
    I'll pop down lunch time to check mine as I so rarely open the rears, I can't actually remember what mine do however my understanding is that it drops for closing the door rather than opening ... ie if you slammed it shut with it not dropping, you would probably end up smashing the glass so that fact the doors do open means your rear glass is not getting stuck in the seal.
    I've been seeing a fair few threads about TT's and the windows not dropping as the temperature drops so that's going to be fun!
    Audi A7 Black Edition 3.0 TDI (272) 2015 (FL)
  3. Re: Rear Windows stick under weather seal on opening
    May 2007
    Brookfield
    Hi Akash,
    Cheers, be good to know how yours react.
    I checked more carefully today, seems the fronts drop when the handle is pulled, whereas the rears seem to only drop when the courtesy light is triggered, suppose they do 'kind of clear' on opening, but do as you say only fully shut when the door is shut.
    Fronts may have a micro switch, maybe the rears don't. Must have a look at the wiring diagram.
    haha Yes when my wife's mk1 boxster windows freeze up I use de-ice fluid it's too scary otherwise! its defo micro switches
  4. Re: Rear Windows stick under weather seal on opening
    Mar 2008
    11 Post(s)
    Thanks for reminding me to reply as I did check over lunch!
    So mine is exactly the same as yours.. In actual fact you just have to start pulling the front handle out till you hit a little resistance and it drops.
    Rears nothing until actually opened and like you said, the lights inside turn on.
    I'd say it's pretty normal
  5. Re: Rear Windows stick under weather seal on opening
    May 2007
    Brookfield
    Thank you for checking, good to be normal!
    Just received a USB stick WS manual, this looks like it won't be a quick install....
    Cheers Akash
  1. Cutting weather seal to allow window tinting?
    By Perrina in forum Vehicular windows, Glazing and Tinting
    Last Post: 15-07-2014, 07:09 PM
  2. Rear Passenger Windows keeps opening on its own - Help with errors
    By wytco0 in forum VCDS - General Questions
    Last Post: 18-12-2011, 11:37 PM
  3. Windows Opening on there own
    By adrianwalker in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-12-2010, 11:09 PM
  4. All windows Keep opening !
    By steeley69 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-02-2010, 11:01 PM
  5. misty windows in passat in cold weather
    By ttank2610 in forum Passat - Archive Topics
    Last Post: 22-02-2007, 07:30 PM
