Thread: Low rev hesitation/judder
Results 11 to 20 of 22
  1. Re: Low rev hesitation/judder
    Jan 2017
    Yeah I will certainly read the blocks when I get VCDS back and then report back here for the results of that. Then I will look at getting down the dealership and grabbing a loom!
    Either way will update you guys here.
    Merry Christmas to you both 😁
    Jamie
  2. Re: Low rev hesitation/judder
    May 2015
    Kirmington, North Lincolnshire
    Would second the injector loom.
    Mine was noticeably worse when the engine was cold, and always seemed to give trouble below 2000rpm.
    Started about 170k, was at 175k and getting worse when I changed it. Problem went away immediately.
    2003 Audi A6 Avant 1.9 tdi Sport
  3. Re: Low rev hesitation/judder
    Jul 2015
    Staffs
    46 Post(s)
    A faulty loom wont always show up on VCDS.
    Ian
    A4 B6 Avant Nogaro Blue
  4. Re: Low rev hesitation/judder
    Jan 2016
    Wiltshire
    Quote Originally Posted by rowdy-999 View Post
    If there’s no Fault Code recorded then using Measuring Blocks will show if there’s a larger compensation discrepancy between the injector with a loom fault and those without. How much that needs to be before throwing a fault I don’t know but the available maximum is +3 or -3. Our Alhambra has roughly only +/-0.2 difference between each injector with a fresh loom. Before that one was running around +1.75 above the others and probably on occasion upto +3. This had a Fault Code in the memory.
  5. Re: Low rev hesitation/judder
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by mrcheesbrough View Post
    Being intermittent it may not always show up.
    Ian
  6. Re: Low rev hesitation/judder
    Jan 2016
    Wiltshire
    Indeed. It took three years for us to actually change the loom as I waited for the Fault to develop in the hope it would become more definite/obvious. Wish I’d done it sooner. It’s a different car now.
  7. Re: Low rev hesitation/judder
    #17
    Jan 2017
    So i've got VCDS today and managed to get the logs on the injector group. I did logs in different situations like idle and then holding a set RPM. I did notice the values don't seem to sit still and when i first started the car up one of the injectors just randomly started climbing and then came back down on its own again?
    I Should probably note that all these tests were done at a stand still, i did not actually drive the car.
    I have attached the files in case any of you can tell me what you think?
    car injector logs.zip
    Thanks for the help so far guys!
    Merry Christmas
    Jamie
  8. Re: Low rev hesitation/judder
    #18
    Jan 2016
    Wiltshire
    Quote Originally Posted by jmejamie View Post
    Merry Christmas
    Jamie
    Probably not best analysed with a stomach full of red wine and turkey but at a glance Cylinder 2 injector seems a bit ‘lazy’ - there are periods where it makes no compensation when I’d expect it to float a little. Cylinder 1 injector spends a lot of time in high negative compensation figures. I would expect this to be a lot more in line with the other injector figures really. Worth noting that although it’s in high negative compensation, it’s still within tolerance so probably won’t throw a Fault Code. However if you’ve more than one injector effected by a faulty loom the combined effect would be quite dramatic. A loom change is relatively simple and cheap compared to any of the other parts you might change to identify further possible causes of the fault.
  9. Re: Low rev hesitation/judder
    #19
    Jan 2017
    Thanks for taking the time to look at those logs for me Mrcheesbrough! Hope you enjoyed your Christmas dinner!
    I am now waiting for the dealership to open tomorrow so i can give them a call and get a wiring loom ordered.
    Will keep this post updated. Fingers crossed this is going to be my fix!
    I looked at the log files after you said about injector 2 being lazy and i can see what you mean. 2 seems to do very little changing under most the scenarios i created for it and injector 1 seems to just be in a world of its own compared to injector 3&4.
    Thanks again
    Jamie
  10. Re: Low rev hesitation/judder
    #20
    Jan 2017
    Right so the new loom came today! Snapped the old one in half to remove it because it was a pain in the *** on my engine compared to others where the engine isn't inline and they can slide it out with easy access. I did make sure any pinging plastic bits were kept away from the internals. I had a fight with the new one but got it fitted now and not really had a chance to drive it properly yet. I did get some more logs of both idle and 1200 RPM in case someone can take a look and determine if it is looking any healthier?
    New loom logs.zip
    Just curious to ask... i have put a fair amount of injector cleaner through the car in its time and had a carbon clean done. Given that there is a chance this injector was being lazy what are the chances that i might need to give it more of a clean if it hasn't been running optimally?
    Thanks guys
    Jamie
  1. hesitation
    By zollaf in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 24-08-2015, 03:40 PM
  2. W reg a3 1.8t quattro judder / hesitation
    By shamus309 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 30-04-2013, 12:16 PM
  3. Please Help gti tdi 150bhp idle judder and low throttle judder
    By rs250gpracer in forum Golf MK4 - 1999 - 2004
    Last Post: 16-02-2010, 10:42 AM
  4. Ive Fixed My A4 Tdi Judder At Last Please Read If You Have A Judder
    By justin@justinwa in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-11-2009, 08:32 PM
  5. 130od judder / hesitation
    By SebRogers in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-02-2009, 03:02 PM
