Thread: Trying to source parts
  1. Trying to source parts
    Dec 2017
    Sweden
    Hi Folks,
    Firstly, I am based in Sweden but I dont mind ordering from the UK as I can have friends forward to Sweden.
    I'm trying to get my hands on part number 5G0805413C - this is the daft little plastic cover under the wing to give access to the front headlight bulbs - made form the cheapest plastic possible as both my drivers and passengers have split on the first bulb change, this could be weather related as it was minus 9 when i was doing the work.
    I digress, I can find them on eBay from Lithuania - which are obviously fake but seem to be my only option at the moment.
    Any suggestions?
  2. Re: Trying to source parts
    Mar 2016
    Minervois, France
    53 Post(s)
    I can't help with the parts except to suggest that your friends in the UK might find them in a breaker's yard.
    About the broken plastic parts, it seems that VAG and other manufacturers are unaware that most plastics become very hard and brittle at low temperatures when they design items which have pissy little clips and barbs to hold them in place.
    A friend in a local garage suggested warming plastic items gently with a heat gun before removing or replacing them - or wait for warmer weather.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  3. Re: Trying to source parts
    Dec 2017
    Sweden
    Thanks for the reply, I suspect you are correct, typically bulbs never stop working in the height of summer.
  4. Re: Trying to source parts
    Mar 2016
    Minervois, France
    53 Post(s)
    I just finished replacing my rear dampers. It took far longer than I ever imagined, due to the large amount of stuff which had to be removed to gain access to their upper mounting bolts.
    Among the parts to be removed were the trim panels around the load area. Some of the nasty little spring clips broke away from their mountings, so I had to spend more time glueing them back in place.
    At least I was able to fit a tow-bar at the same time, which I had put off doing because the trim panels covered the access to the mounting bolts.
    If I ever need to replace the dampers again I'll cut access holes in the trim and refix them with Velcro
    I think body designers place all the components in a heap, design a body to cover it, then leave someone else to fit them all into the finished car.
    For the inevitable bits that are added later to make extra USP's, they make a template of the part and crawl around inside the car looking for somewhere it will fit.
  1. Cheap Bosch Wipers and other Parts at Euro Car Parts this Weekend (25% Off)
    By mikeecix in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-10-2011, 06:22 PM
  2. Can Someone Help Me Source Parts/Part Numbers?
    By Stuart_B in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-07-2011, 05:53 PM
  3. Anyone willing to help source UK parts for US VAG nut
    By vdub-son in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 02-04-2011, 10:46 AM
  4. Source for Ford parts?
    By Issac Hunt in forum Chat - Completely Off Topic
    Last Post: 21-02-2010, 03:40 PM
  5. Cruise Control Parts Source
    By Newt1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-01-2009, 10:07 AM
