Thread: rear nearside sidelight and brake light not working b7 estate
  1. rear nearside sidelight and brake light not working b7 estate
    Jun 2015
    United Kingdom
    i have noticed that my nearside rear side light and brake light are not working on my b7 estate. the nearside tail light on the boot is working, just the one on the corner lens thats not. I noticed that one of the pins in the wiring connector that fits into the lens had broke off so I soldered a wire from the lens to the wiring plug, it was the brown earth wire that had broken.Its not the bulb as I have swapped it over with the drivers side and works fine., when i connect a trailer board to the car, all the lights work on the trailer board too, nearside side light and brake light. there is no bulb failure light on the dash either.. any one have a clue where to look?
  2. Re: rear nearside sidelight and brake light not working b7 estate
    Feb 2016
    manchester,uk
    14 Post(s)
    check if you have electric in the connector both live and earth using a meter or swap the lens over.
  3. Re: rear nearside sidelight and brake light not working b7 estate
    Jun 2015
    United Kingdom
    Quote Originally Posted by f927 View Post
    It's a single filament bulb that operates tail light and brake light. Can bus...what voltages should I expect?
  4. Re: rear nearside sidelight and brake light not working b7 estate
    Feb 2016
    manchester,uk
    14 Post(s)
    you are checking to see if you have current there so you can eliminate either there is issue with the connector or the lens.
  5. Re: rear nearside sidelight and brake light not working b7 estate
    Jun 2015
    United Kingdom
    No current at back light cluster. Or a plug going into cluster.
  6. Re: rear nearside sidelight and brake light not working b7 estate
    Feb 2016
    manchester,uk
    14 Post(s)
    you have break in the wiring.
  1. Q7 rear brake light not working
    By Jonathan B in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 03-03-2016, 12:56 PM
  2. Please Help A3 Rear Nearside side light not working (new bulb does not help)
    By hilly703 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-09-2014, 04:43 PM
  3. Rear brake light not working
    By tpl288 in forum Golf MK3 - 1993 - 1999
    Last Post: 15-02-2010, 12:41 PM
  4. Question Audi A4 2003 nearside rear brake light not working
    By sdjr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-02-2009, 06:02 PM
  5. Nearside Rear Window has stopped working???
    By nemo2182 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-06-2007, 10:10 PM
