Help! Audi A6 randomly fails to start runs through ESP / ABS fault on the dash and coil light stays on. Eventually the car starts if left for long enough after the fault. Any help appreciated, Vag scan below shows ECU issue which is quite worrying, hopefully a guru can help suss this out?
Wednesday,13,December,2017,12:05:48:22207
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.1.0 (x64)
Data version: 20171130 DS276.6
Ross-Tech: Home
VIN: WAUZZZ4F07N048611 License Plate: MT56
Mileage: 232270km-144325mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56
61 62 72 76 77
VIN: WAUZZZ4F07N048611 Mileage: 232270km-144325miles
01-Engine -- Status: Sporadic communication error 1000
02-Auto Trans -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F5 910 401 HW: 4F0 907 401 C
Component: 2.7L V6TDI G000AG 0010
Revision: --H03--- Serial number:
Coding: 0011372
Shop #: WSC 02334 785 00200
VCID: 5EB9E01989612AB6C3-800A
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 E HW: 09L 927 156 C
Component: AG6 09L 2.7 TDI 132 0010
Revision: --H01--- Serial number: 4225662
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 275785FD96BBAB7EF0-8072
2 Faults Found:
006273 - Powertrain Data Bus: Missing Message
P1881 - 000 - Acceleration Request - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 230057 km
Time Indication: 0
Date: 2017.11.15
Time: 17:06:27
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 53.0°C
T.B. Angle: 60.0°
049408 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 230057 km
Time Indication: 0
Date: 2017.11.15
Time: 17:06:27
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020872
VCID: 66C9C8F9513172760B-8032
2 Faults Found:
02083 - Message for Delay Request
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 28
Reset counter: 37
Mileage: 232270 km
Time Indication: 0
Date: 2017.12.12
Time: 16:51:06
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0082
Hex Value: 0x002B
Hex Value: 0x057C
Hex Value: 0x00FF
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 004 - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 20
Reset counter: 37
Mileage: 232270 km
Time Indication: 0
Date: 2017.12.12
Time: 16:51:22
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0782
Hex Value: 0x0014
Hex Value: 0x4390
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100520954
Coding: 0000147
Shop #: WSC 02323 785 00200
VCID: 63CFD1EDA203075EEC-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
1 Fault Found:
00230 - Transmission Park Selector Switch (F305)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 232270 km
Time Indication: 0
Date: 2017.12.12
Time: 16:58:13
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350HL067714053
Coding: 0001002
Shop #: WSC 02335 785 00200
VCID: 254B8FF5ECB7B96EC2-8070
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H02 0060
Subsystem 2 - Serial number: 00000000509048
Subsystem 3 - Serial number: 0129.08.060000000100010384’
Subsystem 4 - Serial number: 010384’
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F2 820 043 N
Component: KLIMABETAETIGUNGH20 0170
Revision: 00000031 Serial number: 00000000303360
Coding: 0001302
VCID: 5BBFE90D9A733F9EA4-800E
2 Faults Found:
00739 - Coolant Circulation Pump (V50)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 3
Fault Frequency: 62
Reset counter: 38
Mileage: 229726 km
Time Indication: 0
Date: 2017.11.11
Time: 14:34:01
Freeze Frame:
Temperature: 78.0°C
01314 - Engine Control Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 38
Mileage: 232270 km
Time Indication: 0
Date: 2017.12.12
Time: 16:51:22
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0010101
VCID: 31636BA5A87FE5CE2E-8064
Subsystem 1 - Part No: 4F2 910 113 A
Component: Wischer AudiC6 H04 0190
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8179232
Shop #: WSC 00000 000 00000
VCID: 1C3DAA11DFFD78A66D-8048
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4E AIRBAG AUDI8RH29 0280
Revision: 08H29000 Serial number: 0037LD0GF582
Coding: 0013381
VCID: 295383C580AF9D0EE6-807C
Subsystem 1 - Serial number: 6332CSME1235666A0
Subsystem 2 - Serial number: 6342CSME123E3C1A8
Subsystem 3 - Serial number: 6352QSME143A21312
Subsystem 4 - Serial number: 6362QSME13780859J
Subsystem 5 - Serial number: 63734SME13504963W
Subsystem 6 - Serial number: 63834SME1006157BX
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90025062210124
Coding: 0102142
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 981 F
Component: KOMBIINSTR. M73 H18 0110
Revision: 00400000 Serial number: 5HS556R86
Coding: 2049443
Shop #: WSC 00107 210 105924
VCID: 234F91EDE283475EAC-8076
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 30
Reset counter: 37
Mileage: 232270 km
Time Indication: 0
Date: 2017.12.12
Time: 16:51:07
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300806801816C
Coding: ECFE53C41B3104
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 37
Mileage: 232270 km
Time Indication: 0
Date: 2017.12.12
Time: 16:51:07
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
Component: MNS ECE H48 1060
Revision: 00000000 Serial number: 364H3067587848
Shop #: WSC 00508 210 06808
VCID: 3B7F498D7A331F9E84-806E
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: 9„‰
Coding: 0003706
Shop #: WSC 02327 785 00200
VCID: 2C5D7AD18F5D88261D-8078
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01018861730000
Coding: 0008955
VCID: 2E5970D9B941FA3633-807A
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 25
Reset counter: 37
Mileage: 232270 km
Time Indication: 0
Date: 2017.12.12
Time: 16:51:15
01699 - Motor for Central Locking; Hatch/Trunk (V53)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 3
Reset counter: 251
Mileage: 230426 km
Time Indication: 0
Date: 2017.11.20
Time: 06:48:05
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 G HW: 4F0 035 223
Component: Amp.-ASK H10 0350
Revision: 44S00001 Serial number: 00108060330403
Coding: 0000103
VCID: 224194E9FD994E56A7-8076
1 Fault Found:
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 214
Reset counter: 253
Time Indication: 0
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000277994
Coding: 0001103
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 30
Reset counter: 38
Mileage: 232268 km
Time Indication: 0
Date: 2017.12.12
Time: 16:51:00
Freeze Frame:
Voltage: 10.100 V
Temperature: 7.0°C
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00-00000
Coding: 0003706
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
Component: EPB CB4C0060 H04 0060
Revision: --H04---
Coding: 0000521
Shop #: WSC 02324 785 00200
VCID: 1F479D1DCEEB63BE88-804A
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 28
Reset counter: 37
Mileage: 232264 km
Time Indication: 0
Date: 2017.12.12
Time: 16:51:06
Freeze Frame:
Voltage: 10.66 V
Count: 241
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394H2067676566
Coding: 0000001
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000097118
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2608213589
Coding: 344630393135313035442056413032363038323133353839
Shop #: WSC 00000 384 00290
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 38
Mileage: 232270 km
Time Indication: 0
Date: 2017.12.12
Time: 16:51:07
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0003114
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0003114
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06230622901318
Coding: 0001016
Shop #: WSC 131071 102 209715
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H13 1130
Revision: 00000000 Serial number: 00000007570294
Coding: 0010920
End-------------------------(Elapsed Time: 03:03)--------------------------
