Thread: Brake Pad Warning - Costs?
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
  1. Re: Brake Pad Warning - Costs?
    #31
    Apr 2016
    berkshire
    38 Post(s)
    Quote Originally Posted by Nemo78 View Post
    Ahh the flaming brake pad/discs fiasco
    So the price I originally saw and you are seeing now is correct and what I paid....
    The lower price which I saw on the day is an error and took Audi about 3 days to fix. I provided some feedback to Audi CS who came back really quickly in all fairness and explained that website was undergoing an update and was bringing back incorrect price.
    However my feedback did get me a ‘gesture of goodwill’ of a free next service
    I did also check the price on my original 65 plate Q7 and that mirrored the price that jldiablo was seeing - so definitely some change in the MY16 and MY16 v2 which has the reinforced floor
    Cheers buddy thanks for confirming this .. Will get braced for the price impact ..
    Sent from my Pixel 3 XL using Tapatalk
  2. Re: Brake Pad Warning - Costs?
    #32
    Oct 2020
    Leicester, United Kingdom
    Hi Retom, can you provide more details on this please? My local Audi specialist is saying I need to change discs n pads for both front and rear. Also I am now having a parking brake fault - came out of no where. The technician said, it's coz the pads are running low which I find hard to believe.
    Has anyone else faced parking brake faults when pads are low?
    I got the following quotes for replacing front & rear discs and pads;
    - Audi Wolverhampton : £749 (front discs & pads) | £575 (rear discs & pads)
    - Local garage using OEM parts sourced directly from dealer : £737 (front discs & pads) | £300 (rear discs & pads)
    Appreciate any help,
  3. Re: Brake Pad Warning - Costs?
    #33
    Apr 2010
    Surrey
    23 Post(s)
    Yes you get a fault when pads are low. There ware sensors in the pads. The dealership must have checked and confirmed that your discs are thin as well, hence recommended a complete pads and discs change. They are quite expensive, and doesn’t seem many cheaper alternatives around.
  4. Re: Brake Pad Warning - Costs?
    #34
    Jul 2010
    uk
    162 Post(s)
    Quote Originally Posted by Evorcious View Post
    The price from Audi Wolves isn’t bad at all as I remember mine was initially quoted as £2k and then reduced to £1650ish or something? It’s all somewhere in this thread.
    Depending on how old your Q7 is worth popping your Reg in to this and seeing what the Audi Fixed Price is (but this is for cars over 3 years old)
    yourAudi Fixed price services < Account < Audi < Audi UK
  5. Re: Brake Pad Warning - Costs?
    #35
    Jan 2018
    Warsaw
    59 Post(s)
    Replacement of discs and pads is not very complicated and can be done by almost every garage. Almost every - since for the rear discs&pads there is a need a computer with a special procedure. However majority of garages have it. This is CA 2 hours job.
    In terms of prices, you have to make your own calculation. All needed parts you will find here: https://www.autodoc.co.uk/car-parts/...113153-3-0-tdi
    If you don't have OEM numbers make your search based on your car PR numbers. Recommend pads: Textar, TRW , Brembo and ATE, discs; Brembo, Zimmermann, TRW (rear), Textar or ATE. All these producers supply AUDi for the first assembly. In Q7 you have probably Brembo or Zimmermann discs, Akebono calipers, Textar and TRW pads. You will need also 4 brake sensors. Brake sensors are not a "rocket technology" and you can choose cheaper as ABS.
    PS. Yes, parking brake error is caused by worn brake pads.
  6. Re: Brake Pad Warning - Costs?
    #36
    Oct 2020
    Thank you all for prompt replies. I am getting my car checked by another garage just for a peace of mind and then decide if I should change the discs and pads straight away. Will keep you guys posted
  7. Re: Brake Pad Warning - Costs?
    #37
    Jan 2018
    Warsaw
    59 Post(s)
    If you have the warning brake light do not delay the replacement too long. Usually it should be done within max. 300-500 miles.
  8. Re: Brake Pad Warning - Costs?
    #38
    Oct 2020
    Retom, I don't have any brake warning lights yet, brakes work fine and no squeeky noises yet. The only error on the dash is the 'Parking brake fault'. I am looking to change them if needed anyhow. Hopefully the parking brake fault will clear when I change the pads and discs.
  9. Re: Brake Pad Warning - Costs?
    #39
    44 Post(s)
    1001 Post(s)
    I have seen worn rear pads cause a parking brake error when the pads are low.
    If you care about the future of the planet, read this and watch the video
    https://www.bosch.com/stories/synthetic-fuels
  10. Re: Brake Pad Warning - Costs?
    #40
    Oct 2020
    Thanks Crasher, glad that its nothing else I went to a few other garages today and they all reccomended changing the pads, apparently discs got some more life on them. Need to get it booked in now.
    While we are at it, can I ask if anyone managed to source drilled& grooved discs for Q7, is it possible without changing the calipers? I couldn't find much on the web but found a video on Q7 being upgraded to Brembo GT series brakes, and have to say they look damn good. Found a source that quoted an eye watering £4.5k for this upgrade kit.
    【UNBOXING ︳Audi Q7 4M with Brembo GT Series 8 POT Front Brake Kit】 - iCARMIX HK - YouTube
  1. Brake warning lights on after brake change?
    By rAy6 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 26-04-2017, 04:30 PM
  2. Replaced Brake fluid (bled system). Red Brake warning light appears!
    By keemaklan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-12-2010, 03:21 PM
  3. Question Engine warning and parking brake warning lights on at same time
    By ajh in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-05-2010, 05:33 PM
  4. ABS warning and Brake Red Warning - power supply fault??
    By martink in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-06-2009, 10:58 PM
  5. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
