Thread: Clutch pedal is hard. Cannot press it at all.
  1. Clutch pedal is hard. Cannot press it at all.
    Sep 2017
    Albania
    I am not able to press my clutch pedal at all. I parked the car 1 hour ago (a golf 4, 1.6 akl, 1999), and when I pressed the clutch it remained all the way to the floor. Managed to take it back with my hands, and when I tried to press the clutch, it was too hard.
    Is there any temporary solution for this. Is this something fixable?
    Thank you in advance.
    Sent from my Nexus 5 using Tapatalk
  2. Re: Clutch pedal is hard. Cannot press it at all.
    1837 Post(s)
    The pedal has broken and the push rod bent and pushed through the box section that holds a white clip. Usually you can get away with leaving the master cylinder push rod bent. You will need the pedal, plastic clip and clutch pedal switch operating pad.
    1 1 0
  3. Re: Clutch pedal is hard. Cannot press it at all.
    Sep 2017
    Albania
    Hello Crasher,
    Thank you for all your help.
    I finally managed to take the car to a garage. The mechanic said that it was broken a lever, I don't know how it is called. It was under a green cap, on the gearbox, next to the front wheel. I found an image on google, and highlighted the broken part. I am hoping that this is something easy to find. :/
  4. Re: Clutch pedal is hard. Cannot press it at all.
    1837 Post(s)
    That is a rare failure these days. On the old 020 box it was an occasional problem but the design of the finger was strengthened for the 02K version of the 020 box when it gained a hydraulic clutch for the PQ34 platform. I would suspect it is because the pressure plate has gone heavy. A cheap easy fix anyway.
    1 1 0
  5. Re: Clutch pedal is hard. Cannot press it at all.
    Sep 2017
    Albania
    The car is ok now, but the mechanic did a temporary solution because we couldn't find a new part. He welded it until we find a new one.
    I want to order the part online, but I don't know how it's called or if it has a specific code.
  6. Re: Clutch pedal is hard. Cannot press it at all.
    1837 Post(s)
    modern fleaBay generation kids, no idea about proper shoppin, You could be really radical and go to a VW dealer or local TPS where you park, get out of the car and go to a counter where you speak to a real person, not Pay Pal and buy one over the counter, part number 02K 141 709 A and £20.14 + VAT. I remember when I fitted a Sachs Sporting clutch to my Golf 1 GTI and the lever split almost immediately. I had a road test to do with a magazine the next day so I welded it up as a temporary fix, that was at least 20 years ago and it is still in there, mind you the car has been off the road for 10 years...
    1 1 0
  7. Re: Clutch pedal is hard. Cannot press it at all.
    Sep 2017
    Albania
    This is my first car actually, and I have so much things to learn about maintenance and solving these kind of problems with it.
    It's very helpful to know that there are people willing to help, and with so much knowledge and experience
    I will keep the part number as a backup plan than. If it fails me again, I will go to the shop and buy it.
    Thank you again for all your help!
  1. Replies: 6
    Last Post: 29-02-2016, 10:05 PM
  2. Clutch Pedal very hard???
    By H17E5H in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 09-04-2010, 11:02 PM
  3. Question Why does the esp light appear every time I press the brake pedal
    By nutter1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-01-2009, 05:00 PM
  4. Please Help brake lights only come on when press pedal hard... is it sensitivity?
    By Smalls in forum Touran - Sharan - Caravelle
    Last Post: 17-07-2008, 01:14 PM
  5. Clutch pedal hard to press
    By djsoftware in forum Alhambra
    Last Post: 06-04-2008, 09:19 PM
