Thread: Audi A4 B8 2.0TDI - Coolant temperature drops down when heater on
Results 11 to 20 of 32
  1. Re: Audi A4 B8 2.0TDI - Coolant temperature drops down when heater on
    Jul 2015
    London
    6 Post(s)
    Quote Originally Posted by Gunnark100 View Post
    So if you start your car and drive heater on...how long it takes car to warm up to 90 degrees?
    You said dealer swapped many parts for test etc...what parts they tested?
    Depends of the outside temperature,traffic and how hard you push the car. If its cold outside and stuck in traffic it wont warm up even after 1 hour driving. Dealership changed thermostat,and tested the water pump and egr valve,they have also checked hoses and pipes. Audi specialist tested the hoses that have thermostat in it and some sort of one way valve, and they also tested the heater control valve.
  2. Re: Audi A4 B8 2.0TDI - Coolant temperature drops down when heater on
    Jul 2015
    London
    6 Post(s)
    Quote Originally Posted by Audidua View Post
    Is your car facelift? I've had the same problem with my b8 2008 2.0tdi 105kW and solve it with replacing hidden thermostat 1K0 121 113A which is placed in rubber hose 03L 121 157 B which connects egr cooler and oil cooler. That hose is not part of newer engines on facelift cars.
    Yes is facelifted model. I think my car have that hose as audi specialist said they have tried to swap from another car but the issue was still the same. I will suggest audi dealership to do the same. The problem with dealership is that all communication goes throus service advisors and they dont have idea what are we talking about and they dont even listen.
  3. Re: Audi A4 B8 2.0TDI - Coolant temperature drops down when heater on
    Oct 2012
    Estonia
    64 Post(s)
    Do you guys have aux heater also?
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  4. Re: Audi A4 B8 2.0TDI - Coolant temperature drops down when heater on
    Dec 2008
    12 Post(s)
    I dont have auxiliary heating only suplementary heater which isnt part of cooling system.
  5. Re: Audi A4 B8 2.0TDI - Coolant temperature drops down when heater on
    Oct 2012
    Estonia
    64 Post(s)
    Ok, in that case, this will not apply to you:
    Audi A4 B8 2.0 TDI Diesel 130kw COOLING SELENOID VALVE WATER PUMP 4H0121671D | eBay
    Just few reports from 130kw and this was a issue, without vcds error, but this valve is just front of aux heater by diagram, not in generic coolant diagram...
  6. Re: Audi A4 B8 2.0TDI - Coolant temperature drops down when heater on
    Jul 2015
    London
    6 Post(s)
    I think that i also have the supplementary heater as when temperature below 7 degrees the cabin is getting warm even when coolant temperature is 0 degrees.
  7. Re: Audi A4 B8 2.0TDI - Coolant temperature drops down when heater on
    #17
    Oct 2012
    Estonia
    64 Post(s)
    Quote Originally Posted by IgorUK View Post
    I dont have english copy(ATTACMENT), so use translate etc....do not show this to dealer otherwise they give you keys and say it is normal!
    Was your climate update this action?
    2013-16 A/C software upgrade service advisory issued - AudiWorld Forums
  8. Re: Audi A4 B8 2.0TDI - Coolant temperature drops down when heater on
    #18
    Jul 2015
    London
    6 Post(s)
    Im not sure about the climate update as i havent got the letter from them. They phoned me up and booked the car.The update took about 25 mins.
    Ive read the russian file and i can say its a lot of crap in one file. I have my car for 2 and half years and this is first time to have this issue. Last 2 winters even on -10 the engine was warming up fast with heater/fan on full blast and coolant temp was staying on 90 degrees. The dealership is sending technical data to audi germany for now and waiting for advice. I will call the tommorow to ask if they checked the thermostat in the hose.
  9. Re: Audi A4 B8 2.0TDI - Coolant temperature drops down when heater on
    #19
    Oct 2012
    Estonia
    64 Post(s)
    I know its crap, but this is AUDI a.s cover crap...
    As i read a bit this italiano thread, looks like there one guy did somekind of costum solution...as i guess egr termostat opens at 75 degrees and in traffic this will cause lower temps...
    Anyway hopefully audi will resolve your issue...just dont take keys until it has been fixed!
  10. Re: Audi A4 B8 2.0TDI - Coolant temperature drops down when heater on
    #20
    Jul 2015
    London
    6 Post(s)
    The problem with audi dealerships is that they are going to start charging money soon, once they start charging i will have to take it back,as ive already spent a lot on it. At the end i might end up trading it in, i should swap the egr valve and tyres before that lol
  1. Please Help A4 b8 2.0tdi 105kW problem with coolant temperature
    By Audidua in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-10-2019, 08:44 AM
  2. Question Audi a4 3.0tdi coolant temperature issue
    By nuty_bloke in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-03-2015, 01:00 PM
  3. Question Loss of coolant and erratic heater temperature
    By Denimblue in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-04-2013, 08:36 PM
  4. Temperature Gauge Drops
    By mk07 in forum Golf MK4 - 1999 - 2004
    Last Post: 03-12-2009, 01:54 PM
  5. Drops of oil on outside of coolant tank
    By Stu8 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-11-2008, 10:21 PM
