Thread: Anyone got a 1) Q7 e-tron manual in PDF format 2) wind noise from passenger side door/mirror
  1. Anyone got a 1) Q7 e-tron manual in PDF format 2) wind noise from passenger side door/mirror
    Dec 2009
    Dublin, Ireland
    25 Post(s)
    Hello all
    I have my Q7 e-tron a week now and overall it has exceeded expectations.
    2 Questions
    1) has anyone got a PDF manual for the Q-7 e-tron. I only have the electronic manual in the car, and am not inclined to sit in the car and digest that. I do have a PDF for the normal 2017 Q7, but one for the e-tron would be good. The supplying dealer is looking...
    2)Overall noise suppression is very good, but I suspect some unwanted turbulence from the passenger door-mirror area when travelling at 120kph (70mph). I suspect a door seal is not fitted / aligned perfectly in this area, as there is no corresponding noise on the driver side. Only noticeable on the motorway with radio off. Has anyone had similar experiences, any thoughts. I googled it and found some similar references in US Q7 threads. I can start proving with tape, etc, but it freezing outside
    Thanks!
    Hugh
    Dublin
  2. Re: Anyone got a 1) Q7 e-tron manual in PDF format 2) wind noise from passenger side door/mirror
    Nov 2017
    Northern Europe
    1) I have not been able to find a pdf myself but through the myAudi-login page you should have access to an electronic version of the manual (have you made an account?). And this is better than a dumb pdf since you can navigate more easily through the document.
  3. Anyone got a 1) Q7 e-tron manual in PDF format 2) wind noise from passenger side door/mirror
    Apr 2016
    Stansted
    169 Post(s)
    I made a pdf when I got mine (May 17). Does have an e-tron section but not sure if as in-depth. Would probably be good enough for offline use?
    I saw a better pdf on the Audiworld site but would probably be missing the European options.
    Section on e-tron:
    Former Q7 owner
  1. Auto dimming heated door mirror passenger side
    By peter goble in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-01-2015, 11:25 PM
  2. Wind noise from drivers side
    By chatty123 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-01-2014, 04:10 PM
  3. Wind noise emanating from driver's door or mirror?
    By HHGTTG in forum Golf MK6 - 2009 - 2013
    Last Post: 05-05-2011, 04:00 PM
  4. Auto Dipping passenger side door mirror
    By DAVID5416 in forum Golf MK6 - 2009 - 2013
    Last Post: 17-10-2009, 01:54 PM
  5. Question mk5 Golf wind noise - drivers side
    By petesaysblimey in forum Golf MK5 - 2004 - 2009
    Last Post: 03-09-2009, 09:26 AM
