Thread: Bad Audi Day
Results 1 to 10 of 15
  1. Bad Audi Day
    Port Talbot, South Wales
    44 Post(s)
    Nightmare today. Autoglass changed the windscreen and set off a host of problems. ACC, Anti Braking Guard, Main Beam Assist & Adaptive Lighting - all not working. They recalibrated the screen camera, cleared the faults and started the car again. Same problems. They said we haven’t done anything, all we can do is recalibrate. I said ‘well it was working when I brought it in’. They said wheel alignment may be out so I’m taking it for an all wheel alignment on Monday and they are going to try recalibrating again.
    So what do you think a) about what’s causing the problems and b) what I should do if the recalibration doesn’t work?
  2. Re: Bad Audi Day
    Tripletrouble Guest
    a) Incompetent fitters.
    b) Get it fixed by Audi and bill them
    0 2 0
  3. Re: Bad Audi Day
    Feb 2013
    Finland
    13 Post(s)
    Wasn't there two cameras, one simple for HBA and second for ACC & other stuff? All errors related to mirror base equipment, which they have taken out and re-fitted. Maybe wrong glass tint, there is only few available in VCDS?
  4. Re: Bad Audi Day
    May 2008
    40 Post(s)
    Oe screen or one of their screens?
  5. Re: Bad Audi Day
    44 Post(s)
    Quote Originally Posted by lynalldiscovery View Post
    Not sure. Theirs I’m guessing. Is there a big difference?
  6. Re: Bad Audi Day
    Feb 2013
    Gloucester
    57 Post(s)
    Have a look at the screen (bottom right I think) for the Audi logo. If that’s missing then it’s their copy and probably part of the reason it not working
    Sent from my iPhone using Tapatalk Pro
    Audi A7, S-line, 313 PS BiTDI Tiptronic, Daytona Grey, heated front and rear seats, Audi connect, quad zone climate control, ski chute and bag, Rear tints, 75 Litre fuel tank, All LED headlights, Night vision assistant, Rear view camera with corner view, Navigation plus, MMI touch, Heads up display, Adaptive Cruise control, Blind spot monitoring and active lane assist. Audi A5 (wifes) My Kit car blog - http://mitchsgbszero.blogspot.co.uk
  7. Re: Bad Audi Day
    44 Post(s)
    Quote Originally Posted by M1tchy View Post
    Says Pilkington on the glass.
  8. Re: Bad Audi Day
    Feb 2013
    Finland
    13 Post(s)
    There should be Audi logo and part code, those codes (choices) can be seen with VCDS.
  9. Re: Bad Audi Day
    Feb 2014
    United Kingdom
    9 Post(s)
    OEM/ESG/ARG is exactly the same part, produced on the same factory, using the same components, sometimes even the same naked glass (with logo). The only difference is less strict quality control - aftermarket parts could have more defects, such as scratches, inclusions, abrasions etc.
  10. Re: Bad Audi Day
    44 Post(s)
    Quote Originally Posted by mReen View Post
    Can’t imagine that would apply to Pilkington. They’re one of the best brands in the glass business. Their quality must be high.
