Thread: Bad Audi Day
Results 1 to 10 of 15
  1. Bad Audi Day
    Port Talbot, South Wales
    33 Post(s)
    Nightmare today. Autoglass changed the windscreen and set off a host of problems. ACC, Anti Braking Guard, Main Beam Assist & Adaptive Lighting - all not working. They recalibrated the screen camera, cleared the faults and started the car again. Same problems. They said we havenít done anything, all we can do is recalibrate. I said Ďwell it was working when I brought it iní. They said wheel alignment may be out so Iím taking it for an all wheel alignment on Monday and they are going to try recalibrating again.
    So what do you think a) about whatís causing the problems and b) what I should do if the recalibration doesnít work?
  2. Re: Bad Audi Day
    68 Post(s)
    a) Incompetent fitters.
    b) Get it fixed by Audi and bill them
    0 2 0
  3. Re: Bad Audi Day
    Feb 2013
    Finland
    9 Post(s)
    Wasn't there two cameras, one simple for HBA and second for ACC & other stuff? All errors related to mirror base equipment, which they have taken out and re-fitted. Maybe wrong glass tint, there is only few available in VCDS?
  4. Re: Bad Audi Day
    May 2008
    27 Post(s)
    Oe screen or one of their screens?
  5. Re: Bad Audi Day
    33 Post(s)
    Quote Originally Posted by lynalldiscovery View Post
    Not sure. Theirs Iím guessing. Is there a big difference?
  6. Re: Bad Audi Day
    Feb 2013
    Gloucester
    53 Post(s)
    Have a look at the screen (bottom right I think) for the Audi logo. If thatís missing then itís their copy and probably part of the reason it not working
    Sent from my iPhone using Tapatalk Pro
  7. Re: Bad Audi Day
    33 Post(s)
    Quote Originally Posted by M1tchy View Post
    Says Pilkington on the glass.
  8. Re: Bad Audi Day
    Feb 2013
    Finland
    9 Post(s)
    There should be Audi logo and part code, those codes (choices) can be seen with VCDS.
  9. Re: Bad Audi Day
    Feb 2014
    United Kingdom
    9 Post(s)
    Have a look at the screen (bottom right I think) for the Audi logo. If that’s missing then it’s their copy and probably part of the reason it not working
    OEM/ESG/ARG is exactly the same part, produced on the same factory, using the same components, sometimes even the same naked glass (with logo). The only difference is less strict quality control - aftermarket parts could have more defects, such as scratches, inclusions, abrasions etc.
  10. Re: Bad Audi Day
    33 Post(s)
    Quote Originally Posted by mReen View Post
    Canít imagine that would apply to Pilkington. Theyíre one of the best brands in the glass business. Their quality must be high.
