Thread: Central locking rear door offside(uk) not working
  1. Central locking rear door offside(uk) not working
    Dec 2017
    Hope Valley
    I'd appreciate any advice
    My central locking works on all doors except one
    You can hear the mechanism trying but the manual locking button won't rise
    I pull the handle and it rises but wont stay up however hard I try to grip it
    I cant open the door to remove the cover etc.
    Is there any way to open the door without damaging the cover
    Thanks in advance for any advice
  2. Re: Central locking rear door offside(uk) not working
    Oct 2016
    Ipswich UK
    I feel your pain. I had the same problem. The electric deadlock has stuck on. If you search the forum I should find I cured it by very carefully drilling a small hole exactly over the location of a torx screw which when loosened allows the locking arm to detach , thus allowing door to open.
    I got new locking module for about 25 quid from eBay which has worked ever since (came from Lithuania iirc). So before doing job get a new module and a selection of torx drivers down to t5 including t8 iirc.
  3. Re: Central locking rear door offside(uk) not working
    Oct 2016
    Ipswich UK
    Btw I was on front passenger door but principle the same. Hole is luckily just between door trim n door seal.
  4. Re: Central locking rear door offside(uk) not working
    Dec 2017
    Hope Valley
    Quote Originally Posted by MrPassat02 View Post
    Hi
    the rear passenger door is firmly closed/locked and no torx screw is visible
    Once I have the door open I believe I can manage as I have all the necessary tools
    Could you be more precise as to where I should drill the hole?
    Maybe a photo or some kind of illustration
    My main problem is to get the door open as it's necessary for the MOT
  5. Re: Central locking rear door offside(uk) not working
    Oct 2016
    Ipswich UK
    Here is the thread, read this;
    Greetings and the dreaded door lock question.
  6. Re: Central locking rear door offside(uk) not working
    Oct 2016
    Ipswich UK
    And here is the bit about locating and drilling hole to expose the deadlock arm
    How To overcome the deadlock on the rear doors
  7. Re: Central locking rear door offside(uk) not working
    Dec 2008
    Had this problem myself (with it progressively getting worse) and put off changing the lock until, like yours, the lock stopped working totally. I found that a sharp bang to the exterior of the door just below the rear of the handle while operating the central locking opened it that one last time and I fitted a new lock straight away. No damage to the door and it's now the smoothest locking/unlocking door on the car.
    Just a recommendation, once the new lock is fitted check both locked and dead locked positions release as they should without closing the door. Easy to do with a suitable screwdriver substituting for the pillar mounted latch and well worth it, you really don't want to go to all this trouble only to find that the door won't open again (for whatever reason) after the new lock is fitted.
  1. Replies: 0
    Last Post: 22-05-2017, 05:44 PM
  2. Replies: 2
    Last Post: 12-06-2015, 08:42 PM
  3. Please Help Rear Offside Break Light and Central Locking Issue
    By Maidment78 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-09-2009, 05:51 PM
  4. Rear door central locking not working...
    By stormbringer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-03-2009, 11:45 AM
  5. Replies: 1
    Last Post: 14-10-2007, 12:06 PM
