Thread: Another day in paradise!
Results 1 to 10 of 11
  1. Cool Another day in paradise!
    Oct 2017
    Tadley
    23 Post(s)
    Another day another jam, at least the Q7 cabin is a lovely place to be! :-)
    0 2 0
  2. Re: Another day in paradise!
    Jul 2016
    Hampshire
    18 Post(s)
    I was expecting the audio to be Phil Collins, not radio 4!
  3. Re: Another day in paradise!
    Mar 2010
    10 Post(s)
    92 Post(s)
    Stop driving in efficiency mode!
    Sent from my SM-G928F using Tapatalk
    2016 Q7. Nuff Said.
  4. Re: Another day in paradise!
    Nov 2015
    U.K.
    34 Post(s)
    Quote Originally Posted by andyhud007 View Post
    I thought it would have said E2 not D2 in efficiency mode? Odd, Im sure mine does.
    Q7 MY16 272PS S-Line Tech/Tour/Trailer packs, orca black, 21 inch 9.5J rims, rotor grey leather, sunroof, BOSE, ambient lighting, reversing cam, drivers memory seat. Gtechniq Crystal Serum Ultra. Sent from my iPad using Tapatalk.
  5. Re: Another day in paradise!
    Apr 2016
    Stansted
    136 Post(s)
    Good spot! Mine goes to E2 as well.
    MY16 Q7 S line 3.0 TDI (272) - Daytona Grey, Dynamic pack, Technology pack, Parking pack adv, Pan sunroof, Black leather, Bose, Matrix LED, Adv key, Driver/Pass elec memory, Sound insulating windscreen, Elec adj steering column, Heated rear seats, Heated windscreen, Rear side airbags, Audi smartphone interface, Ambient lighting, Heated steering wheel, Heated folding door mirrors.
  6. Re: Another day in paradise!
    Jul 2010
    uk
    92 Post(s)
    Traffic Jam Assist - the best feature / option ever
    I dont think mine says E1 etc just as above D1 and Efficiency underneath it
  7. Re: Another day in paradise!
    Mar 2010
    10 Post(s)
    92 Post(s)
    Mine says E1 / 8 when in Efficiency.
    2016 Q7. Nuff Said.
  8. Re: Another day in paradise!
    Oct 2017
    Tadley
    23 Post(s)
    Yes I had wondered about this, I swear I have seen it say E1/E2 etc. but most of the time it seems to show D1/D2, I don't know why it shows D1/D2 rather than E1/E2 if in efficiency mode.
    Also I have noticed the coasting doesn't always engage, I have economy tips enabled and it tells me to take my foot off the accelerator, sometimes it goes to "D" with no number, other times it shows D8. So I guess D8 is engine braking and "D" is coasting, maybe it uses the satnav to work out what to do as it will tell me to lift off if coming up to a 30mph speed limit or roundabout. It's bloody clever but I sometimes I just don't know why it's doing "D8" as opposed to "D".
    Stop/start is also a conundrum, I have figured out that a light touch on the brake will not cause the engine to cut out, press harder and it cuts. But sometimes it completely disables stop/start and the engine won't cut out no matter how hard you stomp on the brake. Sometimes I will be stopped at lights and the engine cuts out, then for no reason it starts again. And other times when I am just crawling/braking/crawling/braking it will cut out and then immediately restart, this can get pretty annoying and it would be a good if there is a way to tune stop/start to stop it being so aggressive, almost like it needs a delay (e.g don't cut out for 1 second after the stop threshold has been activated).
    Would be nice to understand what benefits efficiency mode gives me compared to the other modes, probably need to read the manual again.
    Now I am an old fart I seem to be more pre-occupied with mpg than mph these days. ;-)
  9. Re: Another day in paradise!
    Apr 2016
    Stansted
    136 Post(s)
    It might default back to D when you turn off? Not sure Ive stayed in efficiency mode for very long as it feels like taxi driver mode i.e feels like its always in too high a gear and avoids higher revs.
    Pretty sure youre right in that the coasting mode takes the sat nav info into account when deciding when to engage or not. A quick click of the right gear paddle enables you to manually select it - certain rules still apply, think you need to be above 40 mph etc etc
    On the start/stop, i prefer to select the auto handbrake which changes the behaviour so it cuts out every time unless the usual exceptions prevent it - battery charge, air con, Sport mode etc
  10. Re: Another day in paradise!
    Apr 2016
    Stansted
    136 Post(s)
    Noticed that after trying out Efficiency mode two days ago, mine stays in E the following day.
  1. Paradise by the dashboard light
    By MacHighlander in forum Golf MK6 - 2009-2013
    Last Post: 28-04-2011, 10:57 PM
