Thread: Footwell lights wired to interior roof light
Results 1 to 10 of 33
  1. Question Footwell lights wired to interior roof light
    Dec 2017
    7 Post(s)
    New here so hi!
    I have just bought a 2010 A4 Avant Special Ed and I'm wanting some footwell lights. Theres non already in but wouldn't mind some subtle red in the footwells. I previously had a Civic Type-R FN2 and I tapped into the wiring from the interior light (Dome light) so there all worked in sequence and it looked great.
    Does anyone know if this can be done? Or point in in the direction of locating this wire? Any plans wiring diagrams or help would be great!
    Thanks!
  2. Re: Footwell lights wired to interior roof light
    Aug 2016
    South Lakes, UK
    29 Post(s)
    Personally I'd use an add a fuse in the fuse box. Less messing about.
    Sent from my ONEPLUS A3003 using Tapatalk
  3. Re: Footwell lights wired to interior roof light
    Dec 2017
    7 Post(s)
    I’ve thought this but I don’t really want them on all the time. I’d rather them just come on with the interior light and go off with them if that makes sense?
  4. Re: Footwell lights wired to interior roof light
    Oct 2012
    Estonia
    64 Post(s)
    Quote Originally Posted by MaRsH0 View Post
    Make oem solution...
    AudiEnthusiasts Vag Com
    How To Retrofit footwell lights front/rear
    Retrofit Footwell Lighting - Audi A5 Forum & Audi S5 Forum
    If you want test - connect one to interior circuit...but i dont know will this throw error or not...due different power consumption...
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  5. Re: Footwell lights wired to interior roof light
    Dec 2017
    7 Post(s)
    Cheers for those! I’ve read through all of them to see what I can come up with.
    I was wondering if it would bring an error up.
    I’m not that up on all this Vag-com stuff so not really sure what I’m doing there.
  6. Re: Footwell lights wired to interior roof light
    Oct 2012
    Estonia
    64 Post(s)
    Probably not as led normally use only 1,5-3w each...and some people have added rear ones to front circuit- also no errors etc!
  7. Re: Footwell lights wired to interior roof light
    Aug 2016
    South Lakes, UK
    29 Post(s)
    Why not tap into the fuse for interior lights then. Doesn't have to be a permanent live fuse you add onto. I went this route in my brother's car after using one to install my dash camera.
  8. Re: Footwell lights wired to interior roof light
    Oct 2012
    Estonia
    64 Post(s)
    Quote Originally Posted by jmagee View Post
    Yep good idea, but he wants lights work as interior ones(not on when driving etc), so "supply" should be taken after master switch i guess...
  9. Re: Footwell lights wired to interior roof light
    Dec 2017
    7 Post(s)
    So don't you think tapping into those wires will work how I want?
    If it's going to be too complicated to do what I need, then I'll just take power from a fuse. Which would be the best you think? So they go off when the ignition does?
  10. Re: Footwell lights wired to interior roof light
    Oct 2012
    Estonia
    64 Post(s)
    This is up do you, what final result you like...
    If you want 100% dublicate interior lights(via master switch)...
    1. take supply from a "main" bulb terminal...but you need to check with multimeter which side is + or - ...pita to tap or solder there!
    2.smaller 4pin connector is the one to the rear reading lights...by logic one wire should be from masterswitch(as you can control rear dome lights via front switch also) and one should be same as for bigger connector...which is which...no idea...there is red and red-blue...one of them should have power if car is unlocked and other should have power only if master switch is on or in auto position(engine not running)...so you can check this with multimeter and tap into this one which is connected to the main switch...could be wrong
  1. Question No ambient light setting in low 3G 2016 MMI - footwell lights.
    By Thorpemark in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 18-11-2018, 09:06 PM
  2. Please Help A6 c7 genuine led interior roof lights coding
    By Mgmaestroturbo in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 12-01-2017, 01:33 PM
  3. Replies: 5
    Last Post: 02-12-2013, 06:44 PM
  4. A6 (96) Air bag Light plus interior lights
    By kenny444 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 11-09-2009, 06:00 AM
  5. Remove interior roof light to change bulb?
    By madfella65 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-07-2008, 12:03 AM
