Thread: Footwell lights wired to interior roof light
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
  1. Question Footwell lights wired to interior roof light
    Dec 2017
    7 Post(s)
    New here so hi!
    I have just bought a 2010 A4 Avant Special Ed and I'm wanting some footwell lights. Theres non already in but wouldn't mind some subtle red in the footwells. I previously had a Civic Type-R FN2 and I tapped into the wiring from the interior light (Dome light) so there all worked in sequence and it looked great.
    Does anyone know if this can be done? Or point in in the direction of locating this wire? Any plans wiring diagrams or help would be great!
    Thanks!
  2. Re: Footwell lights wired to interior roof light
    Aug 2016
    South Lakes, UK
    12 Post(s)
    Personally I'd use an add a fuse in the fuse box. Less messing about.
    Sent from my ONEPLUS A3003 using Tapatalk
  3. Re: Footwell lights wired to interior roof light
    Dec 2017
    7 Post(s)
    Iíve thought this but I donít really want them on all the time. Iíd rather them just come on with the interior light and go off with them if that makes sense?
  4. Re: Footwell lights wired to interior roof light
    Oct 2012
    Estonia
    46 Post(s)
    Quote Originally Posted by MaRsH0 View Post
    I’ve thought this but I don’t really want them on all the time. I’d rather them just come on with the interior light and go off with them if that makes sense?
    Make oem solution...
    AudiEnthusiasts Vag Com
    How To Retrofit footwell lights front/rear
    Retrofit Footwell Lighting - Audi A5 Forum & Audi S5 Forum
    If you want test - connect one to interior circuit...but i dont know will this throw error or not...due different power consumption...
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+
    Other: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, B/O tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Chrome door handles, Efficiency prog via cluster & gateway flash...
  5. Re: Footwell lights wired to interior roof light
    Dec 2017
    7 Post(s)
    Cheers for those! Iíve read through all of them to see what I can come up with.
    I was wondering if it would bring an error up.
    Iím not that up on all this Vag-com stuff so not really sure what Iím doing there.
  6. Re: Footwell lights wired to interior roof light
    Oct 2012
    Estonia
    46 Post(s)
    Probably not as led normally use only 1,5-3w each...and some people have added rear ones to front circuit- also no errors etc!
  7. Wink Re: Footwell lights wired to interior roof light
    Dec 2017
    7 Post(s)
    Quote Originally Posted by Gunnark100 View Post
    Ah right! Very useful info there Gunnark100, thanks a lot!
    Next thing then, you wouldn't happen to know how to remove the interior light would you?
    I just had a quick look and there is a torx screw in the sunglasses pocket but surely must be held on with more than that.
  8. Re: Footwell lights wired to interior roof light
    Oct 2012
    Estonia
    46 Post(s)
    Yes, thats all you need, remove torx it will drop down from that end a bit and just pull it gently off!
    from 1min 30 or so...
    Audi A4 & A5 B8 LED interior dome light conversion tutorial - YouTube
    Edit: Not keen to double check, but interior light "power" should be from j519...located above pedals so to say....makes a bit easier to route the wires then via dome!
    Connector D (17-pin)
    Pin 17: Terminal 30g - supply (interior light supply)
  9. Re: Footwell lights wired to interior roof light
    Dec 2017
    7 Post(s)
    Thats great!! Thanks so much for those pieces of info!
    I'll have a blast at scotch locking onto the wire at the weekend and see what the results are. Is there a chance something could go wrong with the electrics in any way, from your experience?
  10. Re: Footwell lights wired to interior roof light
    Oct 2012
    Estonia
    46 Post(s)
    Yes, you can hit +wire with ground and fuse will blow...
    Edit: If you have present time under car menu backround or ambient light option and you can control dome dimming now...take power from dome light!
  1. Please Help A6 c7 genuine led interior roof lights coding
    By Mgmaestroturbo in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 12-01-2017, 01:33 PM
  2. Question No ambient light setting in low 3G 2016 MMI - footwell lights.
    By Thorpemark in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-09-2016, 02:55 PM
  3. Replies: 5
    Last Post: 02-12-2013, 06:44 PM
  4. A6 (96) Air bag Light plus interior lights
    By kenny444 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 11-09-2009, 06:00 AM
  5. Remove interior roof light to change bulb?
    By madfella65 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-07-2008, 12:03 AM
