Thread: Footwell lights wired to interior roof light
Results 11 to 20 of 29
  1. Re: Footwell lights wired to interior roof light
    #11
    Dec 2017
    That sounds like something I don't want to happen. When i did it on my Civic, it was as easy as scotch-locking into the wire, but I appreciate these cars have a much more advanced electronics.
    I've just had the dome light out and I've narrowed down the plug to the lighting, but would you know which colour wire is for the lighting? Or know how I could find out? I've attached a picture of said plug and wires. It's the middle plug with the blue wires.
    Thanks again!
  2. Re: Footwell lights wired to interior roof light
    #12
    Oct 2012
    Estonia
    23 Post(s)
    Pin4 red-yellow is supply...
    A48K5 2008 Retrofits: FL Tail, Bixenon, Color DIS, FL S5 Cluster, ADS with button, MMI 3G
    Other: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, B/O tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Chrome door handles, Efficiency program added via cluster+gateway update, A8 2010+ analog clock in process...
  3. Re: Footwell lights wired to interior roof light
    #13
    Dec 2017
    So in theory, if I scotch-lock into that I should get power to my LED's? What would I put the black wire on my LED Strip to?
    Sorry, I'm a bit of novice when it comes to electronics!
  4. Re: Footwell lights wired to interior roof light
    #14
    Oct 2012
    Estonia
    23 Post(s)
    Quote Originally Posted by MaRsH0 View Post
    Black- you mean your light ground wire...if so....tap into brown one!
    Can you dim your lights now via mmi(ambient or backround light option under car menu) or not, my previous question???
  5. Re: Footwell lights wired to interior roof light
    #15
    Dec 2017
    That's great!
    I don't have that option no. I don't think the car came with the 'interior light pack' so that option isn't enabled on there. Will that have an effect on what i want to do? I'm not bothered about having any control over the lights, I just want the footwell lights to mimic the interior light, if that makes sense.
  6. Re: Footwell lights wired to interior roof light
    #16
    Oct 2012
    Estonia
    23 Post(s)
    That's great!
    No more questions or instructions...thats fine...just if you had that option, we(you) should tap wires a bit different way(as dimming wire is running to dome light also)...but it does not matter anymore:=).
  7. Re: Footwell lights wired to interior roof light
    #17
    Dec 2017
    Thanks so much for your help Gunnark100!! Really really helpful stuff there.
    I'll give this a go either tomorrow or Saturday and I'll let you know how I get on!!
  8. Re: Footwell lights wired to interior roof light
    #18
    Oct 2012
    Estonia
    23 Post(s)
    No problem, glad to help
    Edit: I think my info was not 100% correct, as we taking supply before switch-you will have lights on all the time except if car is locked!
  9. Re: Footwell lights wired to interior roof light
    #19
    Aug 2016
    South Lakes, UK
    9 Post(s)
    Why not tap into the fuse for interior lights then. Doesn't have to be a permanent live fuse you add onto. I went this route in my brother's car after using one to install my dash camera.
    Sent from my ONEPLUS A3003 using Tapatalk
  10. Re: Footwell lights wired to interior roof light
    #20
    Oct 2012
    Estonia
    23 Post(s)
    Quote Originally Posted by jmagee View Post
    Yep good idea, but he wants lights work as interior ones(not on when driving etc), so "supply" should be taken after master switch i guess...
  1. Please Help A6 c7 genuine led interior roof lights coding
    By Mgmaestroturbo in forum Audi A6 - C7 Forum - 2011-
    Last Post: 12-01-2017, 01:33 PM
  2. Question No ambient light setting in low 3G 2016 MMI - footwell lights.
    By Thorpemark in forum Audi A6 - C7 Forum - 2011-
    Last Post: 05-09-2016, 02:55 PM
  3. Replies: 5
    Last Post: 02-12-2013, 06:44 PM
  4. A6 (96) Air bag Light plus interior lights
    By kenny444 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 11-09-2009, 06:00 AM
  5. Remove interior roof light to change bulb?
    By madfella65 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-07-2008, 12:03 AM
