Thread: Footwell lights wired to interior roof light
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
  1. Re: Footwell lights wired to interior roof light
    #21
    Dec 2017
    7 Post(s)
    So don't you think tapping into those wires will work how I want?
    If it's going to be too complicated to do what I need, then I'll just take power from a fuse. Which would be the best you think? So they go off when the ignition does?
  2. Re: Footwell lights wired to interior roof light
    #22
    Oct 2012
    Estonia
    64 Post(s)
    This is up do you, what final result you like...
    If you want 100% dublicate interior lights(via master switch)...
    1. take supply from a "main" bulb terminal...but you need to check with multimeter which side is + or - ...pita to tap or solder there!
    2.smaller 4pin connector is the one to the rear reading lights...by logic one wire should be from masterswitch(as you can control rear dome lights via front switch also) and one should be same as for bigger connector...which is which...no idea...there is red and red-blue...one of them should have power if car is unlocked and other should have power only if master switch is on or in auto position(engine not running)...so you can check this with multimeter and tap into this one which is connected to the main switch...could be wrong
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  3. Re: Footwell lights wired to interior roof light
    #23
    Dec 2017
    7 Post(s)
    That’s a great tutorial there!! Thanks for that once again!
    After a bit of thought, I think I’m going to take power from a fuse because it will be a lot easier. I’m not 100% confident that I’m not going to mess something up. I’ve only just got the car so I don’t want anything to break haha!
    Could you recommend a fuse to take power from? One that turns on with the ignition?
  4. Re: Footwell lights wired to interior roof light
    #24
    Oct 2012
    Estonia
    64 Post(s)
    Drivers side
    No. Electrical equipment amps
    Fuse carrier (red)
    1 Vacant
    2 Vacant
    3 Lumbar support 10
    4 Dynamic steering 35
    5 Interior light 5
    6 Control unit 1 for vehicle's electrical system 35
    7 Control unit 1 for vehicle's electrical system 30
    8 Control unit 1 for vehicle's electrical system 30
    9 Tilting panorama roof/sun roof 20
    10 Control unit 1 for vehicle's electrical system 30
    11 Vacant
  5. Re: Footwell lights wired to interior roof light
    #25
    Dec 2017
    7 Post(s)
    Would I be best trying different ones until I find one that works? I’m guessing using the fuse for the interior light will mean the footwell lights will be on all the time?
  6. Re: Footwell lights wired to interior roof light
    #26
    Oct 2012
    Estonia
    64 Post(s)
    yes, they will be on...you must look at your legs all the time now
  7. Re: Footwell lights wired to interior roof light
    #27
    Dec 2017
    7 Post(s)
    Hahahah! They will be dim-ish 😂
    I’ll wire it all up and see which fuse works best!
  8. Re: Footwell lights wired to interior roof light
    #28
    Oct 2012
    Estonia
    64 Post(s)
    For ground I used this point, up to you, many places there...
  9. Re: Footwell lights wired to interior roof light
    #29
    Dec 2017
    7 Post(s)
    Ah yes looks perfect! I'll get on with this tomorrow and show you the results
    Just having a look at getting the wire through the centre console. I think i've seen someone else do it on another tutorial so I'll follow that!
  10. Re: Footwell lights wired to interior roof light
    #30
    Oct 2012
    Estonia
    64 Post(s)
    Quote Originally Posted by MaRsH0 View Post
    Forums are not only for seeking benefit and info...so for future guests post your final result/solution
  1. Question No ambient light setting in low 3G 2016 MMI - footwell lights.
    By Thorpemark in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 18-11-2018, 09:06 PM
  2. Please Help A6 c7 genuine led interior roof lights coding
    By Mgmaestroturbo in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 12-01-2017, 01:33 PM
  3. Replies: 5
    Last Post: 02-12-2013, 06:44 PM
  4. A6 (96) Air bag Light plus interior lights
    By kenny444 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 11-09-2009, 06:00 AM
  5. Remove interior roof light to change bulb?
    By madfella65 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-07-2008, 12:03 AM
