Thread: DPF Forced Regen
Results 1 to 10 of 10
  1. DPF Forced Regen
    Dec 2017
    Scotland
    Hi Guys
    First time poster
    not long had my 57 plate A6 avant auto. Keep getting amber warning ⚠️ cleared it once before myself By running it on the motorway but it soon came back. If now has engine management lights dpf light and engine oil pressure light on and to add to this the car is in limp mode and the brakes have gone to. Took it to get diagnostic done and was told it all to do with the dpf and a forced regen would be my best option to resolve the problem?
    Has anyone had any success with a forced regen or are they a waste of time and money?
    Should point out the car only does short journeys and has 174,000 on the clock
    any advice would be greatly appreciated
  2. Re: DPF Forced Regen
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    You don't say what engine it is 2 litre or V6. Get a proper scan done and post the fault codes, don't run it until the oil light is resolved, could be the oil pump drive if its the 2 litre engine. I can't see how a blocked dpf can be affecting the brakes. to be honest with you if you're only doing short journeys this will be a recurrent problem, especially if it is the original dpf on that age / mileage. The filters can be sent away and cleaned.
  3. Re: DPF Forced Regen
    Dec 2017
    Scotland
    Quote Originally Posted by Rob69 View Post
    Thanks for the reply Rob
    It's the 2 litre and they said the brakes were due to a vacum problem and built up gases?
  4. Re: DPF Forced Regen
    Nov 2010
    104 Post(s)
    Did you buy this private or dealer? You still need a proper scan using VCDS or some other decent diagnostic system, post the scan codes up here with the engine code (3 letter code) there seems to be a few different faults with the car, can't see how vacuum problem could be related to the dpf as vacuum pump is independent of the exhaust system, oil pressure problem could be more serious, do some research on this forum and elsewhere regarding the oil pump hex key issue. If you have the option I'd consider taking it back to the dealer and getting them to sort it.
  5. Re: DPF Forced Regen
    Dec 2017
    Scotland
    Bought it private unfortunately. Thanks will do
  6. Re: DPF Forced Regen
    Dec 2017
    Scotland
    Got the codes today
    05746 - coolant fan issue
    09263 - DPF Fault
    06215 - ABS Controller
    00665 - Boost pressure fault
    01826 - Steering angle fault
    02072 - ECU error
    00018 - Cold air flap
    00657 - Centre air flap
    102072 - ECU error
    And various othe faults present relating to sound system and lights
  7. Re: DPF Forced Regen
    Nov 2010
    104 Post(s)
    Wow, lots of seemingly unrelated codes there, is your battery voltage ok? what is the voltage with the engine off and running, should be around 12.5V off and 14.5V running.
  8. Re: DPF Forced Regen
    Dec 2017
    Scotland
    No idea, the garage refused to fix it and sugested going to audi with it. I don't have anything to check it with
  9. Re: DPF Forced Regen
    Nov 2010
    104 Post(s)
    see if you can find a good VAG independent or look on the vcds user location map on this forum, a voltage check would be an easy quick check with a multimeter on the battery terminals.
  10. Re: DPF Forced Regen
    Dec 2017
    Scotland
    Thanks Rob
  1. forced regen
    By nevo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-02-2016, 11:28 AM
  2. Forced sale of my beloved A6.
    By C172s in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 03-11-2014, 08:30 PM
  3. DPF Forced regeneration (idle) last on 4.5s
    By crazy4alfa in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-09-2013, 11:38 AM
  4. DPF Forced Regenerate on 1.6 TDI 90?
    By golfed in forum Golf MK6 - 2009 - 2013
    Last Post: 18-10-2009, 09:31 PM
  5. T5 Forced Entry
    By GJC_Sparks in forum The Commercial Range
    Last Post: 08-11-2007, 09:31 PM
