Thread: Audi A4 Quattro injector issues!
Results 1 to 9 of 9
  1. Audi A4 Quattro injector issues!
    Dec 2017
    Cornwall uk
    Hi all, I'm looking for advice from anybody that knows about injector issues. The story starts when driving home from work one day and the car suddenly looses power and is running very lumpy. It was clear to me I was only running on 3 cylinders. I went home and had the codes read and it was showing "injector 1 pd unit fault". So, I went to a local breakers yard (who have a very, very good name locally) and got an injector, it was checked it was for the correct vehicle/engine. I fitted the new injector and when I started the car it was no better so read the fault codes again and it's now showing injector 4 fault!!! Anybody experienced this before? Or am I just experiencing a case of bad luck and all the injectors need changing? Any help much appreciated
  2. Re: Audi A4 Quattro injector issues!
    scotland
    34 Post(s)
    Suspect the injector wiring harness, well known for this problem. Replacement harness are around the £60 mark.
    With all the heating and cooling cycles the wiring becomes brittle, new harness should be heated before installation to aid manipulation into position, plenty of info on the net regarding this.
  3. Re: Audi A4 Quattro injector issues!
    Dec 2017
    Cornwall uk
    Thanks for the reply, I was starting to wonder if that may be the issue. I'm kind of hoping it is because it's a lot cheaper cure!! I'm having the original injector that I removed tested and if it comes back without fault then my next step will be the wiring. I will keep you informed on how it goes. Cheers again
  4. Re: Audi A4 Quattro injector issues!
    16 Post(s)
    397 Post(s)
    Remember that the injectors have to be dialed in to the engine, the 180 anti-clock turn method. Also ALL bolts are one time only.
    page 1 by Steve Cresswell, on Flickr
    page 2 by Steve Cresswell, on Flickr
    page 3 by Steve Cresswell, on Flickr
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
  5. Re: Audi A4 Quattro injector issues!
    May 2012
    Somerset
    193 Post(s)
    Extremely rare for 1.9 PD 130 injectors to fail , harness and camshaft wear before that .
  6. Re: Audi A4 Quattro injector issues!
    Dec 2017
    Cornwall uk
    So after trying to clean up the connectors on the wiring harness (just thought it was worth a try) and having no luck I now need to get a wiring harness, any idea where I can get one?? I can't seem to find it anywhere!!
  7. Re: Audi A4 Quattro injector issues!
    scotland
    34 Post(s)
  8. Re: Audi A4 Quattro injector issues!
    Dec 2017
    Cornwall uk
    Well I changed the wiring harness and all seemed good until I tried driving up hill and now no power and brake peddle is going hard!! The car is no longer missing so the wiring harness worked and all injectors are working. Is this a case of a vacuum pipe split or not connected properly?
  9. Re: Audi A4 Quattro injector issues!
    scotland
    34 Post(s)
    Lack of vacuum, youíve either missed a pipe somewhere or itís the tandem pump.
  1. Please Help Audi A6 C6 2.7tdi injector issues?
    By Lbcvantage in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-10-2017, 01:21 PM
  2. Audi B8 3.0 TDI Quattro S-Line E+ MPG Issues
    By lithium in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-12-2016, 10:22 PM
  3. Audi A4 Avant 2.5 TDI Quattro Issues
    By tobiasnugent in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-03-2011, 08:48 PM
  4. Question Audi A4 2.6 Quattro issues
    By sparticus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-09-2010, 07:17 PM
  5. Towing issues with audi a4 quattro tdi b8
    By john-mandy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-03-2010, 06:50 PM
