Thread: Boost Pressure Sensor Location
  1. Post Boost Pressure Sensor Location
    Sep 2014
    North Wales
    BLS Engine. 1.9 TDIe.
    Cant locate the boost pressure sensor location.
    Was hoping ing one of you wonderful people could share a schematic.
    I experienced increased fuel consumption and intermittent limp mode. Error code was 0334 from memory. Turbo over pressure indication all the same anyway. recently had to replace the exhaust pressure sensor so it makes sense they’re going wrong ina similar time frame.
    Thanks in advance. And apologies if I’ve been a total newb and this has already been raised.
    Stefan.
  2. Re: Boost Pressure Sensor Location
    Sep 2014
    North Wales
    So in being sad and replying to my own post. One assumes it’s on the turbo intercooler hose leading into the turbo. At the lower passenger side of the engine bay.
    Next question. What’s the easiest way to get to that bit. Wheel arch trim?
  3. Re: Boost Pressure Sensor Location
    Jan 2009
    Birmingham
    17 Post(s)
    is it item 6 in this picture
    Charge air cooler - exploded view
    1 - 8 Nm
    2 - Bracket
    q Note installation position
    3 - Charge air cooler
    q Removing and installing → Chapter
    4 - Sealing panel
    q Attached to top and bottom of charge air cooler
    5 - 3 Nm
    6 - Charge pressure sender -G31-/intake air temperature sender -G42-
    7 - O-ring
    q Renew if damaged
    8 - Bracket
    9 - 5 Nm
    10 - Air hose
    11 - Air pipe
    12 - Air hose
    q To intake manifold flap motor -V157-
    13 - 8 Nm
    14 - Air hose
    q To turbocharger
  4. Re: Boost Pressure Sensor Location
    Sep 2014
    North Wales
    That looks like the sensor sitting in my kitchen. Is that image upside down?
  5. Re: Boost Pressure Sensor Location
    Sep 2014
    North Wales
    great. Just changed it thank you. Image wasn’t upside down. Can’t believe I didn’t see it! Although being slightly fair I was right in that it was on the air flow pipe into the turbo. Lol
    thank you.
    Quote Originally Posted by arman123 View Post
    1 - 8 Nm
    2 - Bracket
    4 - Sealing panel
    5 - 3 Nm
    7 - O-ring
    q Renew if damaged
    8 - Bracket
    9 - 5 Nm
    10 - Air hose
    11 - Air pipe
    12 - Air hose
    13 - 8 Nm
    14 - Air hose
    q To turbocharger
  6. Re: Boost Pressure Sensor Location
    Sep 2014
    North Wales
    Pic
  1. Please Help 1.9 tdi 90 boost pressure sensor
    By chris_90 in forum Vento - 1994 - 1998
    Last Post: 20-04-2014, 10:53 PM
  2. Boost pressure sensor plug location???
    By lloydtown in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 15-03-2014, 11:06 AM
  3. Boost Sensor location - 3.0 TDI BKN
    By JetsetRon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-11-2012, 07:17 PM
  4. Please Help loss of boost, map sensor location
    By andyuk25 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-05-2012, 12:14 AM
  5. Boost pressure Sensor
    By Frankiebaby in forum Golf MK5 - 2004 - 2009
    Last Post: 10-09-2009, 12:11 AM
