Thread: Radiator Blanking
  1. Radiator Blanking
    Feb 2011
    Sutton Coldfield England
    My C5 2.5 TDI with Multitronic in this cold weather is not getting up to normal temperature
    what is the best way of blanking off the front of the car without affecting the air con and oil cooling
    ive tried just blanking the radiator but this is causing the air con to cycle between off and on
    Any practical ideas please
    Bobh
  2. Re: Radiator Blanking
    Nov 2016
    Swindon
    13 Post(s)
    Quote Originally Posted by bobh6742 View Post
    Bobh
    Change the thermostat. Is not easy to access, but is the only real fix.
  3. Re: Radiator Blanking
    Aug 2017
    West Midlands UK
    11 Post(s)
    Indeed, the thermostat should be replaced!
    I recently changed the thermostat on my Zafira as it wouldn't heat up and the seal was leaking, it then went to the other extreme and jammed shut shortly after and cooked the engine, luckily £12 later and another new stat it's fine again.
    I wouldn't like to put a figure on the cost of repairing an Audi if the same occured!
    2003 A6 C5 2.5 TDI Quattro Avant (180bhp)
  4. Re: Radiator Blanking
    Nov 2016
    Swindon
    13 Post(s)
    Another question: are the undertrays still fitted to the car?
  1. Question 2.5 TDI EGR Blanking
    By HAWKS in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-08-2013, 09:15 PM
  2. Blanking the EGR
    By cheekyelf in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-04-2012, 07:43 PM
  3. EGR Blanking
    By dsgrnmcm in forum 1.9TDi - Engine
    Last Post: 21-11-2010, 11:22 AM
  4. Question EGR Blanking?!?!
    By lordpleb in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-06-2010, 10:06 PM
  5. EGR blanking
    By Petemate in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-12-2009, 10:15 PM
