Thread: 3.0 TDI A6, am I mad for considering buying one?
Results 1 to 10 of 14
  1. 3.0 TDI A6, am I mad for considering buying one?
    Jun 2008
    Hi all,
    Am I mad for considering buying a 2004 A6, 3.0TDI.
    55,000 miles.
    Will it lead me to a life of misery?
    Or is it luck of the draw?
    Thanks.to
  2. 3.0 TDI A6, am I mad for considering buying one?
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    Luck of the draw
    C6 or C5?
  3. Re: 3.0 TDI A6, am I mad for considering buying one?
    Jul 2008
    Lisburn
    15 Post(s)
    If it is plain sailing consider it boring... adds character, i bought an 07 with 110K have had a couple of issues but you are in the right place to get them sorted.
  4. Re: 3.0 TDI A6, am I mad for considering buying one?
    Feb 2016
    London
    13 Post(s)
    Quote Originally Posted by hrb93 View Post
    Hi all,
    55,000 miles.
    Thanks.to
    I’d be worried / suspicious about that low a mileage on that age of diesel car - does it have a history explaining this?
    2011 A6 Allroad 3.0TDI
  5. Re: 3.0 TDI A6, am I mad for considering buying one?
    Jul 2015
    Staffs
    46 Post(s)
    Try and get 07+ for improved injectors.
    Ian
    A4 B6 Avant Nogaro Blue
  6. Re: 3.0 TDI A6, am I mad for considering buying one?
    11 Post(s)
    I’ve just bought a 55 plate with 148k on it, so hopefully yours will be fine.
  7. Re: 3.0 TDI A6, am I mad for considering buying one?
    May 2016
    London
    18 Post(s)
    2004-2006 3.0tdi BMK engiens do suffer from chain failures and poor injectors. This was fixed in late 2006 + with ASB engine.
    Sent from my SM-G950F using Tapatalk
  8. Re: 3.0 TDI A6, am I mad for considering buying one?
    May 2014
    Darlington
    78 Post(s)
    Never heard of a chain failure on the BMK engine, the top tensioner can start to fail causing a rattle at start up but the ASB engine also has the same issue. The top tensioners can be replaced with the engine in place.
    Main issue with the BMK engine is weeping injectors which produces lots of smoke, it's more noticeable if the engine is hot and left to idle.
    However a car with only 55K mile should be OK.
  9. Re: 3.0 TDI A6, am I mad for considering buying one?
    11 Post(s)
    Interesting. On my 149k car I know the injectors have been replaced. How do you check if the chain is likely to fail?
  10. Re: 3.0 TDI A6, am I mad for considering buying one?
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    It doesn’t fail. It just makes a noise when you start the engine at both cold and warm. It makes a vruuumm. I personally changed them and after 1-2k kilometres made the same sound.
  1. Question Buying my first A4 avant 2.0tdi, what spec to get and what to look out for when buying?
    By jakm15 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-09-2016, 09:03 PM
  2. What to look out for when buying a tt
    By rolfather in forum TT - 8N Forum - 1998 - 2006
    Last Post: 19-03-2013, 02:08 PM
  3. Buying a A6 What Look Out For?
    By Sti_Prodrive in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-01-2013, 02:28 PM
  4. Please Help Buying next A8
    By Lenb in forum A8 - S8 - V8
    Last Post: 05-11-2012, 08:08 AM
  5. Buying a new GTi
    By n8384 in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 10-01-2008, 10:12 AM
