Thread: Fitting of cruise control 1999' Highline
  1. Fitting of cruise control 1999' Highline
    Hi.
    I have bought a cruise control module for my 1999 Passat Higline 1.9TDI.
    The module looks like this, and is a OEM part:
    The problem is that i have no mounting instructions for this item, and i do not know how it should be fixed.
    Anyone know how to make the cruise control fit and work in my car?
    The car is bought in Norway and has a 1.9 TDI engine, it does not have ESP or any traction control. My local VW dealer told me it should be plug'n play but they refuse to give me the instructions to get the cruise working, as they would rather do the job themselves.
    I also heard that i need a vag-com to enable the cruise control in the ecu after mounting?
    Kind regards
    - Lars
  2. Re: Fitting of cruise control 1999' Highline
    london/ UK
    Do a google search and there should be a write up with pictures on how to do it. Yes you will need vag-com to enable the cruise control.
  3. Re: Fitting of cruise control 1999' Highline
    Anyone who could give me the exact link to the installation guide?
    I did a google search, but i only found a guide for Golf 4.
    Thanks.
  4. Re: Fitting of cruise control 1999' Highline
    Big G Guest
    Quote Originally Posted by rotax800 View Post
    Thanks.
    i have a PDF file buts its too big for the forum. I can email you if you have an address.
    You can also search ebay and a seller in there has a link in the item to the instructions.
    http://cgi.ebay.co.uk/VW-Passat-3B-2...QQcmdZViewItem
  5. Re: Fitting of cruise control 1999' Highline
    Thank you very much.
    Another question, what does the vag-com cost, and what is the name of the "right" vag-com compatible with my car?
  6. Re: Fitting of cruise control 1999' Highline
    Big G Guest
    You can email the file to: lars_foshaug@hotmail.com
    Just sent it. As for vag com the free version is enough. there was a recent post about this explaining where to get it and which version/cable you need.
  7. Re: Fitting of cruise control 1999' Highline
    Ok.
    I will buy a cable and get back to you if any problems occur.
    Thank you very much for helping me out.
  1. Fitting Cruise control
    By TheMadhatter in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-02-2012, 06:03 PM
  2. Cruise Control on 05 Highline
    By Irri_Tant in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-09-2007, 05:26 PM
  3. Fitting cruise control
    By diyer in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-07-2007, 07:00 PM
  4. fitting cruise control on other vw models.
    By redman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-07-2007, 09:48 AM
