Thread: Blower not responding to digital climate control
  1. Blower not responding to digital climate control
    Dec 2017
    Plymouth
    Afternoon all.
    I've got a Seat Ibiza - good stuff 2010 (60 plate) and suddenly the blower is no longer responding to the digital climate control. I've tested and know the following:
    Tested 12V connection direct to blower, fan fires up
    All other functions of climate control panel work (changing vent locations, AC on/off, heat)
    Fan doesn't respond at all on full/low setting
    Not sure what could be left but in the cold weather - clearing the windscreen has become a nightmare.
    I'm guessing it could be something to do with the resistor but don't want to fork out for a new one and fit it if i'm wrong. Has anyone else had a similar issue in the past that can advice?
  2. Re: Blower not responding to digital climate control
    Oct 2017
    leeds
    its usually the diode on the resistor if the resistor is at fault you can usually cut the diode out and solder a new diode on to it the diode should be available from either maplins or rs for just a couple of pounds you could try this before forking out for a new part. check the resistor contacts as wel the contacts on the plug can get burnt out of corroded best thing to do is inspect the resistor first check for corrosion burnt contacts and test the diode to see if it still good
  1. Question climate control blower failure/resistor pack/ control panel ?
    By ianmcneill in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-08-2011, 10:00 PM
  2. Digital Climate Control not blowing fan
    By edlbowe in forum Alhambra
    Last Post: 21-05-2010, 09:33 AM
  3. Heater blower/climate control
    By 1.8tgav in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 17-04-2010, 02:25 AM
  4. Question digital climate control
    By kenshin in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-02-2010, 09:06 AM
  5. A4 Climate Control - No Blower
    By Cactus Greengo in forum Chat - Anything with wheels
    Last Post: 01-02-2008, 11:24 PM
