Thread: Fog lights not working
Results 1 to 10 of 12
  1. Fog lights not working
    May 2010
    carlisle england
    Hopefully someone can help me with this issue.
    My Mk6 golf 2.0Gt Tdi was in for MOT yesterday and has failed due to the fog lights not working. Although only the rear was the failure of the test, both front and back do not work. The bulbs look fine on inspection, when the fogs are switched into the on position there is no icon displayed on the dash. It was also noticed that the dipped beam lights stay on constantly even when the switch is turned to the off position. The car does NOT have the auto headlights function, the headlights are halogen the car is a 2012 model.
    If anyone has any suggestions, I do have VCDS so can investigate further
    Ben
  2. Re: Fog lights not working
    Dec 2014
    Bedford
    42 Post(s)
    Sounds like a faulty switch. Dipped beams stay on by default if the bcm knows the headlight switch is faulty.
  3. Re: Fog lights not working
    May 2010
    carlisle england
    Ah, that may explain things. I will look to buy a new switch and see if that corrects things
  4. Re: Fog lights not working
    Dec 2014
    Bedford
    42 Post(s)
    Push the dial knob in turn to right and pull at the same time and the switch should come out easily.
  5. Re: Fog lights not working
    May 2010
    carlisle england
    I removed it last night and when unclipping the multipin connector there was no change and lights stayed on. I think the replacement switch cost should be a lot lower than an auto electrician so will try the replacement first
  6. Re: Fog lights not working
    1840 Post(s)
    That is a problem in the central electrics unit, does it show any errors and have you been "tweaking" anything?
  7. Re: Fog lights not working
    May 2010
    carlisle england
    When scanned, the only error codes relating to the the exterior lighting were from the disconnection of various plugs to check for anything loose.
    There was also 1 code for the rear heated screen switch that I noticed.
    I used vagcom to turn off the cornering fog lights a while back so do wonder if the instructions that I found online have been incorrect. I know someone with a similar spec car so have arranged to check the long coding in their central electrics module against what I have on mine and also try their headlight switch.
  8. Re: Fog lights not working
    May 2010
    carlisle england
    UPDATE
    After checking the long coding on a friends vehicle of a similar spec I decided to change all coding to the same as theirs, obviously making a note of what was changed. After trying this out I found that nothing changed and the issue was still there so decided to investigate into the fault code of rear windscreen heater, the fuse was ok but upon checking some others I noticed fuse 12 had blown. A check online suggested this was for the rain sensor but my car does not have this function, anyway after changing out the fuse this for some reason unbeknown to me has corrected the issue and has also cleared the rear screen heater fault.
    The electronics on cars these days seem so sensitive that one slight issue can cause another in an alternative place
  9. Re: Fog lights not working
    1840 Post(s)
    Private Message me your reg number and I will tell you what fuse 12 does, pressuambly SC12 in the dash side fuse board?
  10. Re: Fog lights not working
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Quote Originally Posted by Gt140tdi View Post
    Ben
    I don't see how the rear fog lap failed as there is only one on the right, the other side is the reversing light. That's VW being cheap skates for not fitting 2 of each.
    Do you have a fuse & relay diagram for your 2012 Golf?
    You say you have VCDS. Have you done an AutoScan to see if anything shows? You can test any system out as well.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  1. Question vw polo 1.2 twist number plate lights n dashboard lights not working
    By gauchosanto in forum Polo - Derby - Lupo - Fox
    Last Post: 29-09-2017, 07:03 PM
  2. Question A3 Door lights and interior lights not working.
    By Markdr in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 13-01-2016, 04:09 PM
  3. Please Help All interior lights and door lights stopped working in my Sharan 1.9 TDi (Nov 01 New Shape)
    By di4charles in forum Touran - Sharan - Caravelle
    Last Post: 09-01-2013, 01:50 AM
  4. led side lights and number plate lights, not working
    By adamk in forum Audi A3 - Archive Topics
    Last Post: 02-04-2008, 07:37 PM
  5. Puddle Lights and courtesy lights not working
    By PerArdua in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-01-2008, 01:43 PM
