Thread: A4 b7 2008 cabriolet rear number plate lights
  1. A4 b7 2008 cabriolet rear number plate lights
    Jul 2014
    Kent
    Hello All,
    I have a broken driver side rear number plate light lense and I am thinking of upgrading to some of the led type ones I have seen on eBay.
    I know there are some issues with canbus errors with this sort of thing and I'm wondering if anyone else has had any experience with this I'm a b7 cabriolet ?
    The reason I mention about the cabriolet as I don't know if it has its own unique number plate light shape or size ?
    I need 2 rear number plate lights for an Audi A4 b7 Cabriolet.
    Will a4 saloon lights fit in a4 cabriolet ?
  2. Re: A4 b7 2008 cabriolet rear number plate lights
    Jan 2015
    Eastbourne
    Quote Originally Posted by zen200 View Post
    Hello All,
    I've not got a cab, but do have b7 2006 A4. From my research they are all the same fitment, I've got a couple of LED replacements turning up hopefully today in the Post as one of my bulbs has gone, I'll let you know how it goes.
    Paul
    Sent from my Redmi 3S using Tapatalk
    Audi A4 1.8t B5 - W Reg - Now with lambda fault (Bosch part on route from finland!)
    Completed:
    Temp Sensor, Thermostat, Coolant change, Fixed indicator fault, new number plates, LED Number plate lighting, Oil temp sensor, Full filters change + oil + sparks, drain bung blockage removed
    To do ASAP: Drivers side CV Boot, passenger speaker, EVAP Solenoid valve (Part on route)
  3. A4 b7 2008 cabriolet rear number plate lights
    Jul 2014
    Kent
    Ok thanks Paul
  4. Re: A4 b7 2008 cabriolet rear number plate lights
    Jan 2015
    Eastbourne
    Ok thanks Paul
    So my LED replacements arrived and they look good, fitting was easy (well slightly less easy for me because of my number plate holder) single screw to undo and the units have a lip on the opposite side to the screw to hold them in.
    Swapped them over and tested, no errors on the dash at all, I've driven for about 2hours and they have worked flawlessly.
    I've attached a couple of pics.
    If you want the link to the ones I got let me know.
    Paul
    Completed:
  1. Rear number plate lights
    By peter goble in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-05-2014, 08:16 PM
  2. Allroad rear fog lights and number plate lights problem
    By bootie3367 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-08-2013, 10:08 AM
  3. Rear number plate lights
    By PatMcCoy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-08-2011, 11:38 PM
  4. rear number plate lights
    By adamk in forum TT - 8N Forum - 1998 - 2006
    Last Post: 03-08-2009, 08:20 PM
  5. Rear Number Plate Lights - V Reg Polo
    By WesleyP in forum Polo - Derby - Lupo - Fox
    Last Post: 04-06-2009, 06:44 AM
