Thread: High revs
  1. High revs
    Nov 2017
    bucks
    good evening...im having a problem with the revs at the moment..mk4 golf 1.4.
    I accelerate and my needle slows down for a second then drops to 1000rpm or even stops at around 1400 1600 rpm.next it starts revving by itself 2..i clean the throttle body up a month ago, because it was idling at 600 rpm n then 800rpm..didnt sort out the problem at the time...but will switch if when fully locked....recently it has started at 1200rpm then sits at 800rpm after it has warmed up.. and now it plays about..i rev it just over 2000rpm and it stays at around 1400-1600 rpm...any advice please...many thanks.
  2. Re: High revs
    Nov 2017
    bucks
    Also it has been throwing lots of water out from the exhaust..i hope its not the gasket.
  3. Re: High revs
    Jan 2009
    Birmingham
    35 Post(s)
    im sure you have to re calibrate the throttle body using vcds
  4. Re: High revs
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
  1. Loss of power in high revs/high load
    By bannervw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-08-2015, 05:46 PM
  2. high revs 1.6 a3
    By A-Frizzal in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-04-2010, 06:29 AM
  3. 1.9 tdi revs too high
    By njg in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-09-2009, 11:30 PM
  4. Please Help High revs
    By audia4lyn in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-08-2008, 01:18 PM
  5. Kangaroo-ing at low revs and Revs staying high on Gearchange.
    By Dancake in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2007, 05:50 PM
