Thread: Rear brake fault 2006 A6
  1. Rear brake fault 2006 A6
    Dec 2012
    newtownabbey
    Looking a bit of help, changed the rear brake pads and now handbrake isn't working warning lights all over the dash and constant warning tone when driving.
    Brake caliper opened ok and pads replaced, caliper closed fine but half way through test it failed with warning lights and beeping, if you drive there's a constant warning tone until you stop.
    Could this problem be broken connection in the loom?
  2. Re: Rear brake fault 2006 A6
    1840 Post(s)
    What are you using to open/close the caliper motors and what fault codes are stored? The early 4F had very poor parking brake motor wiring plugs, check too see if the plugs have separate or moulded boots. If they are separate plugs and boots, you may have to fit one or even both repair harness sets which have to be let into the main harness in the boot area on the bulkhead. Even then, the controller in the right side panel can play up, disconnecting it for a while can make it STFU!
  1. Audi a6 2006 sometimes will not start - indicating brake fault
    By dpcle in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-03-2018, 08:25 PM
  2. Question VW Passat 2006 parking brake fault - where can I get a switch?
    By mjpassat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-05-2016, 09:47 AM
  3. Rear brake discs. Audi A6 2006
    By Steve_K in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-05-2013, 01:01 PM
  4. Rear brake pads and fault warning
    By gibble in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-07-2011, 03:11 PM
  5. Rear central brake light bulb Fault on A6 Avant 2007
    By OliB in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-02-2011, 08:34 PM
