Thread: 80 Saloon Rear Demister issues..
  1. 80 Saloon Rear Demister issues..
    Nov 2017
    Manchester
    Hello all,
    The rear demister isn't working. Fuses appear to be fine and there is continuity across the circuit on the glass. There is also voltage at the plug at the back of the switch. Am I safe to assume it's the switch that is at fault? (It doesn't light up when pressed) If so, am I only to replace it with the exact part number that is on the original (assuming it's the original)? (4A0 941 503)
    The closest I can find so far is 4D0 941 503B
    Thoughts?
    Cheers 😊
  2. Re: 80 Saloon Rear Demister issues..
    Dec 2007
    8 Post(s)
    A diagram for A6 seems to show the live feed for demister as white/yellow from fuse to switch,then white to unit, the heater mirrors are on same circuit.
  3. Re: 80 Saloon Rear Demister issues..
    Nov 2017
    Manchester
    HI Michael, there is certainly a yellow/white wire to the back of the switch and it gives 12v. That's a good sign surely!
  1. Question Audi a4 B5 Saloon Rear Demister connection
    By akash87 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-11-2014, 03:52 PM
  2. Question Rear Demister - woeful
    By richtung in forum Passat CC
    Last Post: 07-10-2014, 08:14 PM
  3. Please Help Rear Demister
    By rastarrph in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-03-2011, 07:33 PM
  4. Rear Demister not working
    By Neilt74 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-07-2010, 09:29 PM
  5. Rear Demister not working?
    By bpascua in forum Golf MK4 - 1999 - 2004
    Last Post: 15-12-2008, 06:21 PM
