Thread: revs dont drop
  1. revs dont drop
    Jan 2016
    Colwyn Bay
    I have a Mk5 FSI 1600 petrol, when I take my foot off the accelerator to change gear the revs dont drop straight away this only happens when I am moving whether I am in gear or not, when stationary the revs drop down straight away, no fault codes, the fault only occurs when the wheels are turning, any ideas please.
    Rob
  2. Re: revs dont drop
    1840 Post(s)
    You need to check the clutch pedal position sender signal is being recognised by the ECU, do this in Measuring Blocks and VCDS has the labels.
  1. Revs Drop intermittent
    By TJP in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2012, 09:42 AM
  2. Question Rattle noise when revs drop
    By smithy29919 in forum Golf MK4 - 1999 - 2004
    Last Post: 24-02-2010, 08:49 AM
  3. 1.9TDi power drop at certain revs
    By Equinoxstudios in forum 80 - 90
    Last Post: 02-02-2009, 06:30 PM
  4. Ibiza cutting out when revs drop
    By davyboy888 in forum Ibiza - Cordoba
    Last Post: 16-11-2008, 06:46 PM
  5. MK5 TDi revs drop at 2500
    By Loofer in forum Golf MK5 - 2004 - 2009
    Last Post: 25-08-2007, 11:11 PM
