Thread: Fault Code Help Required Please!
  1. Fault Code Help Required Please!
    Nov 2017
    Cardiff
    Hi - I am new to your forum and this is my first post so I hope I am posting this in the correct place!
    Anyhow, I have a 2009 Audi A6 3.0Tdi Quattro Auto Le Mans Edition of which I have owned for the past 2 years without any issues but over the weekend I couldn't gain entry to the vehicle whatsoever, not even the boot as there was zero power.
    I used the key to enter via drivers door and put key into ignition and nothing, no lights, no power etc just a click to lock my key into the ignition of which I couldn't then remove.
    I called breakdown and he managed to jump start vehicle after 5 mins using jump leads, however, not through the battery connectors (as it wouldn't start) but under bonnet but on the actual battery terminals itself - The engine stayed on for a few minutes then died and he then took a further 30 minutes trying to start again but with no luck. Car was cranking but no ignition to start! Glow plug warning light, ESP warning light and a number of other warning lights were flashing throughout the effort of trying to start it.
    Breakdown engineer suggested that I charge the battery as it was dead - I believe it is the original battery on the vehicle as I have all FSH servicing receipts etc. and no mention of a new one so probably time to get a new one.
    Anyhow, I fully charged battery to and placed back in vehicle and MMI showed 100% - I tried to start engine again, cranking over but no ignition - By such time only ESP warming light remained on together will all other usual dashboard lights, plus heating controls, MMI, radio etc. After only a few attempts at restart battery indicator reduced to 75% then after another couple of ignition attempts fell to just 10% so left it.
    After a few hours I heard a noise coming from outside on the drive - I took a look and the car fan was running at full pelt and had started on its own so totally confused me - As soon as I put key back into ignition and tried to start again the fan went off.
    I then had my son use his Carista reader but I also knew someone with a VCDS reader - I have therefore listed below the relevant data from both and wondered if anyone could possibly help me in trying to find out what is wrong before I get it towed to a local Audi Diagnostics Specialist.
    Thank you in anticipation
    Carista Readout
    CAN network gateway:
    03041 - Energy Management Active
    Heater & air conditioning:
    01206 - Signal for Duration of Ignition Off Time
    Instrument cluster:
    00003 - Control Module
    ABS:
    01826 - Sensor for Steering Angle (G85), Voltage Supply Terminal 30
    Engine:
    53271
    P0671 - Glow Plug/Heater Cylinder 1 (Q10) circuit, electrical Fault in Circuit
    Radio:
    00446 - Function Limitation due to Under-Voltage
    Infotainment system:
    03276 - Testing Management Software version
    03175 - Invalid Dataset
    Obtained with Carista 3.6 for iOS.
    VCDS Readout of Fault Codes
    Chassis Type: 4F-AU56 (4F0)
    Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 46 4F 52 53 55 56 5F 62
    69 72 76
    VIN: WAUZZZ4FXAN030785 Mileage: 194980km-121154miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Malfunction 0010
    69-Trailer -- Status: OK 0000
    72-Door, Rear Right -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    Address 01: Engine (CDY) Labels: Redir Fail!
    Part No SW: 4F9 910 402 A HW: 4F0 907 401 E
    Component: 3.0TDI EDC17G000AG 0080
    Revision: 16H02--- Serial number:
    Coding: 0105002C190F0128
    Shop #: WSC 12345 123 45725
    VCID: 2443A69CE7F19166CE-8070
    3 Faults Found:
    053271 - Please Check Fault Codes in Control Module for ABS Brakes
    U1017 - 007 -
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 20:35:33
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Bin. Bits: 00101100
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    001649 - Cylinder 1 Glow Plug Circuit (Q10)
    P0671 - 000 - Electrical Fault
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 00:17:43
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Voltage: 10.56 V
    Temperature: 5.4°C
    Lambda: 13.3 %
    Temperature: 7.2°C
    053286 - Please Check Fault Codes in Transmission Control Module
    U1026 - 001 - - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 20:35:12
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 6.84 V
    Torque: 0.0 Nm
    Bin. Bits: 00000000
    Readiness: 0 0 0 0 1
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F2 910 156 Q HW: 09L 927 156 C
    Component: AG6 09L 3,0 TDI RdW 0040
    Revision: --H04--- Serial number: 4536842
    Coding: 0000001
    Shop #: WSC 02325 785 00200
    VCID: 336155C0521F06DE47-8066
    1 Fault Found:
    006288 - Signal Line for Tiptronic
    P1890 - 000 - Electrical Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 00:16:01
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AL HW: 4F0 614 517 BA
    Component: ESP8 quattro H03 0060
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004492
    Shop #: WSC 00565 210 91524
    VCID: 6ED784B479BD6B3668-803A
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - -
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 83
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 00:17:35
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0282
    Hex Value: 0x0024
    Hex Value: 0x0184
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
    Part No SW: 4F0 910 852 B HW: 4F0 905 852 E
    Component: FBSAUDIC6 ELV H05 0130
    Revision: 00H05000 Serial number: 10603001725516
    Coding: 0000019
    Shop #: WSC 62192 001 1048576
    VCID: 2545BB98ECCB686ED9-8070
    Subsystem 1 - Part No: 4F0 910 132 E
    Component: FBSAUDIC6 EZS H03 0020
    Subsystem 2 - Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0054
    1 Fault Found:
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 8
    Reset counter: 123
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 09:16:15
    Address 08: Auto HVAC Labels: 4F0-910-043.clb
    Part No SW: 4F0 910 043 B HW: 4F2 820 043 AA
    Component: KLIMABETAETIGUNGH30 0080
    Revision: 00000074 Serial number: 00000030475721
    Coding: 0001046
    VCID: 1D359378C49BA0AE81-8048
    1 Fault Found:
    008 - Implausible Signal
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 R HW: 4F0 907 279
    Component: ILM Fahrer H24 0340
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0013121
    Shop #: WSC 02335 785 00200
    VCID: 387B62EC4B79E58672-806C
    Subsystem 1 - Part No: 4F2 910 113 C Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H10 0040
    Coding: 00056595
    Shop #: WSC 02335
    Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH04 0003
    Coding: 00146221
    Shop #: WSC 02335
    3 Faults Found:
    02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 123
    Mileage: 194980 km
    Time Indication: 0
    Date: 2009.06.02
    Time: 00:40:00
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 123
    Mileage: 194980 km
    Time Indication: 0
    Date: 2009.06.02
    Time: 00:41:00
    00532 - Supply Voltage B+
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 123
    Mileage: 194980 km
    Time Indication: 0
    Date: 2009.06.02
    Time: 00:41:00
    Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
    Part No SW: 4F0 035 110 A HW: 4F0 035 110
    Component: CDC-MP3-Alp H44 0140
    Revision: AA001001
    VCID: 15258B58FCABF8EE49-8040
    No fault code found.
    Address 15: Airbags (J234) Labels:| 4F0-910-655-10.clb
    Part No SW: 4F0 910 655 Q HW: 4F0 959 655 G
    Component: Airbag AU1042 H06 0160
    Revision: -------- Serial number: 003F9001ETVG
    Coding: 30314236303630303033554A305234463053
    Shop #: WSC 02323 785 00200
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 35656BD8946B18EE69-8060
    Crash sensor for side airbag: driver side:
    Serial number: 3574SRB4000098250AE8
    Crash sensor for side airbag: front passenger side:
    Serial number: 3584SRB40000980D2A03
    Crash sensor for side airbag: rear: driver side:
    Serial number: 3516HRB402B9ICPIU4PD
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 3526HRB402B9GRDKPSCN
    Crash sensor for front airbag: driver side:
    Serial number: 3554NRB40000507979C2
    Crash sensor for front airbag: front passenger side:
    Serial number: 3564NRB4000050A4003J
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
    Component: J0527 0530
    Revision: 00H05000 Serial number: 90055092660162
    Coding: 0102141
    VCID: 2759B19096C77A7EEB-8072
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 123
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 20:30:03
    Address 17: Instruments (J285) Labels:. 4F0-920-xxx-17.clb
    Part No SW: 4F0 920 983 G HW: 4F0 920 983 G
    Component: KOMBIINSTR. H08 0144
    Revision: 00000000 Serial number: CN343ZM99
    Coding: 2F570A0502002600010400
    Shop #: WSC 02391 823 56573
    VCID: 306B5ACC63093DC63A-8064
    1 Fault Found:
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 83
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 00:17:47
    Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
    Part No SW: 4F0 907 468 M HW: 4F0 907 468 F
    Component: GW-BEM 4CAN-M H06 0035
    Revision: LB100029 Serial number: 2900L0991782FB
    Coding: 000303
    Shop #: WSC 45330 002 1048576
    VCID: 397D67E8B073FC8E8D-806C
    Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
    Component: J367-BDM H07 0107
    Serial number: 00000000004140676395
    2 Faults Found:
    000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 123
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.02
    Time: 23:33:00
    Freeze Frame:
    Bin. Bits: 00011
    Voltage: 10.00 V
    Count: 7
    02256 - Quiescent Current
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 123
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 02:56:00
    Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
    Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
    Component: TSG FA H11 0250
    Revision: Serial number: 0000102000398
    Coding: 011F06204041410001
    VCID: 46871C14F18D8376F0-8012
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 123
    Time Indication: 0
    Address 46: Central Conv. Labels:. 4F0-910-289.lbl
    Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
    Component: Komfortgeraet H29 0250
    Revision: 02500029 Serial number: 01225516260000
    Coding: 0139771
    VCID: 35656BD85C6B18EE69-8060
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H13 0100
    Revision: Serial number: 00000000659645
    Coding: 0001103
    VCID: 5EB7D474891DFBB6D8-800A
    Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
    Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
    Component: TSG BF H11 0250
    Revision: Serial number: 0000102012258
    VCID: 45851B18CC8B886EF9-8010
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 123
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 20:31:49
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
    Component: EPB CEFC0090 H05 0090
    Revision: --H05---
    Coding: 0000321
    Shop #: WSC 02145 785 00200
    VCID: 214DAF88F8E3844EA5-8074
    Address 55: Headlight Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 H
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000003
    VCID: 3F8909F06E57D2BEB3-806A
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4F0 035 056 K HW: 4F0 035 056
    Component: Radio U STD H45 0074
    Revision: AB001007 Serial number: 342JX097684041
    Coding: 010003020100000000
    VCID: 285BB2AC5BD97506E2-807C
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 123
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 09:16:42
    Freeze Frame:
    Voltage: 8.70 V
    Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
    Part No SW: 4E0 035 666 K HW: 4E0 035 666 B
    Component: H-BN-EU H41 0187
    Revision: -------- Serial number: 454JX097516241
    Coding: 010101000102C3ED03002F15EF6300030001
    VCID: 2E5744B4793D2B3628-807A
    Subsystem 1 - Part No: 8R0 060 884 ED
    Component: EUR 2017 2402
    Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
    Component: DU7 High H43 0306
    Serial number: 9356JW091079412
    Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F2 919 611 M
    Component: Bedienteil MM H01 0060
    Serial number: 00000001411745
    Subsystem 4 - Part No: 8R0 906 961 A
    Component: CD-Database 1293
    2 Faults Found:
    03276 - Please Check Software Version Management
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 83
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 00:17:46
    Freeze Frame:
    Voltage: 11.10 V
    03175 - Invalid Data Set
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 83
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 00:17:38
    Freeze Frame:
    Voltage: 11.00 V
    Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
    Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
    Component: TSG HL H10 0251
    Revision: Serial number: 0000009440362
    Coding: 010E04204041220001
    VCID: 43810500C2BFB65ED7-8016
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 123
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 20:31:49
    Address 69: Trailer (J345) Labels:. 4F0-907-383.clb
    Part No SW: 4F0 907 383 C HW: 4F0 907 383 C
    Component: Anhaenger H14 0080
    Revision: 2B002001 Serial number: 00000109827498
    Coding: 0100000000000000
    VCID: 2B514DA04A2F5E1E0F-807E
    Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
    Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
    Component: TSG HR H11 0362
    Revision: Serial number: 0000140734308
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 123
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 20:31:49
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4L0 910 283 C HW: 4L0 919 283 C
    Component: Parkhilfe 8-Kan H02 0500
    Revision: 00H02000 Serial number: 12620927001630
    Coding: 0201006
    VCID: 2A5F48A485D54716F4-807E
    End-------------------------(Elapsed Time: 03:00)--------------------------
    Wednesday,29,November,2017,18:40:10:10862
    VCDS Version: 17.8.0.1 (x64)
    Data version: 20170721 DS276.2
    Ross-Tech: Home
    VIN: WAUZZZ4FXAN030785 License Plate: F11DGT
    Mileage: 194980km-121154mi Repair Order:
    69 72 76
    3 Faults Found:
    U1017 - 007 -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 20:35:33
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Bin. Bits: 00101100
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 00:17:43
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Voltage: 10.56 V
    Temperature: 5.4°C
    Lambda: 13.3 %
    Temperature: 7.2°C
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 20:35:12
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 6.84 V
    Torque: 0.0 Nm
    Bin. Bits: 00000000
    Coding: 0000001
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 00:16:01
    Coding: 0004492
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 83
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 00:17:35
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0282
    Hex Value: 0x0024
    Hex Value: 0x0184
    Hex Value: 0x00FF
    Coding: 0000019
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 9
    Reset counter: 123
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 09:16:15
    Coding: 0001046
    1 Fault Found:
    Coding: 0013121
    Coding: 00056595
    Shop #: WSC 02335
    Coding: 00146221
    Shop #: WSC 02335
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 123
    Mileage: 194980 km
    Time Indication: 0
    Date: 2009.06.02
    Time: 00:40:00
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 123
    Mileage: 194980 km
    Time Indication: 0
    Date: 2009.06.02
    Time: 00:41:00
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 123
    Mileage: 194980 km
    Time Indication: 0
    Date: 2009.06.02
    Time: 00:41:00
    Revision: AA001001
    Coding: 0102141
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 123
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 20:30:03
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 83
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 00:17:47
    Coding: 000303
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 123
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.02
    Time: 23:33:00
    Freeze Frame:
    Bin. Bits: 00011
    Voltage: 10.00 V
    Count: 7
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 123
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 02:56:00
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 123
    Time Indication: 0
    Coding: 0139771
    Coding: 0001103
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 123
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 20:31:49
    Revision: --H05---
    Coding: 0000321
    Coding: 0000003
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 123
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 09:16:42
    Freeze Frame:
    Voltage: 8.70 V
    2 Faults Found:
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 83
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 00:17:46
    Freeze Frame:
    Voltage: 11.10 V
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 83
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 00:17:38
    Freeze Frame:
    Voltage: 11.00 V
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 123
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 20:31:49
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 123
    Mileage: 194982 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 20:31:49
    Coding: 0201006
  2. Re: Fault Code Help Required Please!
    1840 Post(s)
    Quote Originally Posted by AudiA6Dom View Post
    I am a bit confused as the battery is in the boot. Did he jump the battery in the approved way on the battery control box on the rear panel. It sounds like you do need a new battery, change it before you do anything else. To be correct, the battery should be correctly coded into the control unit.
  3. Re: Fault Code Help Required Please!
    Nov 2017
    Cardiff
    Yes actual battery itself is located in the boot and the battery connectors [not sure if that is correct term] are under bonnet - my sentence was a little unclear. New battery on way anyhow, then garage in s few days.
  1. Help with fault code scan required
    By Brycie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-07-2016, 09:43 PM
  2. Vag com engine module log in code required passat 2.5 tdi 2004 (bdg engine code)
    By garyjwilson in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-07-2015, 05:24 PM
  3. Vag com engine module log in code required passat 2.5 tdi 2004 (bdg engine code)
    Last Post: 30-06-2015, 02:31 PM
  4. Fault Code - Advice Required Please -
    By RickT in forum Golf MK4 - 1999 - 2004
    Last Post: 26-08-2011, 09:25 AM
  5. Audi A8 Fault code HELP required
    By Bmw7even in forum A8 - S8 - V8
    Last Post: 03-03-2010, 08:44 PM
