Just an enquiry really...
Will a pair of S6 C5 Xenon HID Head lights unit fit the 2001 Allroad? I am aware that they should be plug and play, even if my old units were the low class H1 double bulb.
Everything looks the same apart from the indicator bulb removal stalk. On the Allroad the point in at about 45 degrees, but the S6 they come straight back.. other than it probably being a right pain to change the indicator bulb, will the miss all the other stuff? Not sure if the Allroad is a bit tighter behind the units..
Regards
Alan
