Thread: Wiper linkage broken at motor connection
  1. Wiper linkage broken at motor connection
    Dec 2015
    Scotland
    9 Post(s)
    Hi folks, we were in the Lake District this weekend and it pretty much rained every day, Sod's law the wipers went coming out of Grasmere a good few hours from Scotland!
    Had a quick look and couldn't do much grabbed some rainx at Halfords in Penrith and got home no issues (worked quite well actually).
    Anyway the car is 2008 and the linkage says 2011 so it's obviously be done before!
    Euro car parts don't show much online it looks like you replace the full linkage system rather than the one rod that is shot what a pain.
    I had to use a puller on the wipers to get them off and was suprised how much pressure it took and penetrating fluid!
    Remember this happened with my dads Carlton 22 years ago and it was 1.45 for the linkage arm from the dealers!
    Audi A6 2008 Saloon Sline 2.0 Tdi BRE
    Vw Passat B7 1.6 tdi 2012 estate
    Previously - 2008 1.6 tdi Mini, 2006 Mazda Mx5 1.8, 2002 Vw Golf 1.9 tdi SE, 2010 Bmw 318d Msport, 1992 Porsche 944 2.5 turbo, 1986 Porsche 944 2.5 NA, 1984 Porsche 944 2.5 NA
  2. Re: Wiper linkage broken at motor connection
    Jul 2013
    39 Post(s)
    you can get a repair plate on ebay for 10 which stops the linkage popping off.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Wiper linkage broken at motor connection
    Dec 2015
    Scotland
    9 Post(s)
    thanks, I had a look at them, are they any good, my linkage where it connects at the motor is very worn in the black platic collar? I see how they work but would it do be a bit rough? I guess its worth a try.
    There are two types one bolts on the other is a clip - apart from driling (not an issue) which would be better?
    https://www.ebay.co.uk/itm/Audi-A6-S...0AAOSwv9hW5Aiw
    A lot of the full linkages online seem to be for left hand drive, I was happy to get a new one on Amazon for 45 however even after stating its RHD its actually for LHD! Very annoying!
    I'm going to take the chance to clean the centre wiper drain hole in the tray under the wiper and other leaves in the upper bulkhead!
    The wiper plate that goes onto the windscreen seems tricky to get on is there a trick, the last person to refit it has really dog eared the edge getting it in!!
  4. Re: Wiper linkage broken at motor connection
    Oct 2014
    England
    Mine went a few days ago, mid sweep. Drilled it and put a self tapper through the cup to hold it in place.
    Removing the trim under the wiper arms is always a **** of a job though, especially when its cold and plastic gets more brittle....
  1. A6 C6 Front wiper linkage come disconnected from motor?
    By helium4amc in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-10-2017, 01:56 PM
  2. Front wiper motor and linkage
    By christyconway in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-08-2013, 12:40 PM
  3. Question A3 Wiper motor and linkage
    By paulkelly77 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 15-07-2009, 05:21 PM
  4. Question Average time to failure for A4 Windscreen wiper motor and linkage
    By Evsie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-07-2008, 10:30 AM
  5. Sharan Front Wiper motor linkage
    By siloverbuzzard in forum Archive posts
    Last Post: 23-12-2007, 02:56 PM
