Thread: Mk2 carburattor issue
  1. Mk2 carburattor issue
    Nov 2017
    Lithuania
    Dear members of forum, I encountered with a tricky issue on my volkswagen jetta 1986 mk2, my tailpipe throw out too much carbon monoxide, so I checked the carburattor and found one pipe (red arrow in image) without any connections, just going nowhere, can anybody help me, I would be most thankfull!
  2. Re: Mk2 carburattor issue
    1840 Post(s)
    That vacuum pipe should vent to atmosphere, it is a temperature dependant vacuum actuator controller which uses the hot water in the choke housing to decrease it's affect as the coolant temp increases. The 2E3 is a very difficult carburettor to repair, it could just be an adjustment issue, a split adjuster tube O ring or any one of a dozen or so problems which can cost more to repair than it does to fit a Weber conversion.
  3. Re: Mk2 carburattor issue
    Nov 2017
    Lithuania
    So I should just leave it opened?
  4. Re: Mk2 carburattor issue
    glasgow
    35 Post(s)
    you could, but you still need to tune the car
    hence stick on a Weber carb
  1. Please Help B6 2.0 tdi Cr 140. EGR/IMF issue
    By Majorlook in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-06-2019, 11:04 PM
  2. b8 tow bar - fan issue - please help
    By s7gpt in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-06-2013, 09:07 PM
  3. a6 oil sensor issue and airbag issue
    By 2400 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-12-2012, 11:26 AM
  4. Brake servo issue and possible linked boost issue
    By slipperyox in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2012, 10:06 PM
  5. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
