Thread: Damned cars
  1. Damned cars
    Nov 2017
    West Yorkshire
    Hello I appear to be receiving a p0670 error from a pals OBD2 meter.
    I’ve done a bit of research and I’ve found that it could be a number of issues.
    First off, how do I check the glow plug harness? Is it a visual or do I need some equipment?
    Secondly could anyone give me a part number for the glow plug heater control unit - just in case that’s the issue.
    Thanks for any help.
    Might be an idea if I give you a clue as to what car it is...
    Golf mk6 1.6 TDI 2011
  2. Re: Damned cars
    Nov 2017
    Scotland
    25 Post(s)
    you need to take the rocker cover off-it is inside the head at front of the cam when you are looking at it from front of the car
  3. Re: Damned cars
    Nov 2017
    West Yorkshire
    The glow plug heater control module?
    I thought that was under the battery carrier.
  4. Re: Damned cars
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    VAG Error Code: 17054/15912/001648
    EOBD II Error Code: P0670
    Fault Location:
    Glow Plug Control Module (GPCM) (J179), Glow Plug Circuit - Electrical Malfunction
    Possible Cause:
    Malfunction Indicator Lamp (MIL)(K83) active.
    Lack/Loss of Power.
    The engine may be harder to start.
    Engine hesitation.
    Wiring/Connector(s).
    Glow Plug Control Module (GPCM) (J179).
    Glow plug(s).
    Engine Control Module (ECM).
    Possible Solutions:
    Check/Replace all faulty Wiring/Connector(s).
    Read Measuring Value Blocks (MVB).
    When is the code detected?:
    The Engine Control Module (ECM) has detected a fault on the Glow Plug Control Module (GPCM) (J179) control circuit.
    As taken from my new EOBD II Error Codes
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  5. Re: Damned cars
    Nov 2017
    Scotland
    25 Post(s)
    Quote Originally Posted by Ivantapoo View Post
    I was/had only bothered with this one--===First off, how do I check the glow plug harness? Is it a visual or do I need some equipment?--haha.
  6. Re: Damned cars
    Nov 2017
    West Yorkshire
    Quote Originally Posted by Vagnuts View Post
    Right. It’ll have to wait until next weekend when I can see.
    It’s not really struggling to start, I’m just sick of seeing the engine management light stuck on.
    While I’m here, have you any idea if the Exide battery can be topped up? Or should I give it an overnight charge? (Start/stop not working).
  7. Re: Damned cars
    Sep 2009
    12 Post(s)
    ElsaWin calls it Automatic Glow Period Control Unit (J179), on left under E-box, 461 from August 2006 identification number 457.
    There are fuse for this. Use a Digital Volt Ohm Meter (DVOM) to test the wiring.
    I have 2012 Golf 1.6 TDI-CR BlueMotion Fuses & Relays 5K122Z CAYC 2008-2011. If you want a copy PM me?
  1. Damned emissions light!
    By beanmasteruk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-11-2013, 02:15 PM
  2. Replies: 20
    Last Post: 09-04-2012, 06:09 PM
  3. Want to know even more about your cars?
    By kamikaze06 in forum Golf MK6 - 2009 - 2013
    Last Post: 23-06-2011, 12:11 AM
  4. Damned clutch pedal!!!
    By producedapples in forum Golf MK4 - 1999 - 2004
    Last Post: 30-10-2009, 01:56 PM
  5. Our Cars!
    By steeevo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-11-2008, 12:26 AM
