Thread: Ac conditioner won't blow hot air. Only cold
  1. Ac conditioner won't blow hot air. Only cold
    Sep 2017
    Albania
    Hi there,
    I have been the owner of a golf 4 1.6 SR for the last couple of months. I have used the AC clima all the summer, but never tried it with hot air.
    Today I checked it, and it blew only cold air, even though I chose the max temperature.
    Is there anything I can check by myself? Is this an expensive fix?
    Thank you in advance.
    Sent from my Nexus 5 using Tapatalk
  2. Re: Ac conditioner won't blow hot air. Only cold
    1840 Post(s)
    A blocked heater matrix, a very very comon problem on older P34 platforms which use a matrix almost identical to the Golf 2 which was very prone to a blocked matrix due to poor maintenance. It is virtually impossible to flush the problem away and the only proper solution is to replace the matrix, it is a cheap part but takes two days to fit.
    1 1 0
  3. Re: Ac conditioner won't blow hot air. Only cold
    Sep 2017
    Albania
    Thank you very much. I think I'll let someone else do it for me then.
  4. Re: Ac conditioner won't blow hot air. Only cold
    Sep 2017
    Albania
    A quick update.
    I noticed that the car temp was low even though I was riding for miles. I changed the thermostat, and it seems that it's blowing hot air finally.
    Hope that this was the solution. Anyway I have to test it on the highway again.
    2 1 0
  1. Air Conditioner Pulley
    By NickW in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-06-2015, 03:02 PM
  2. Air Conditioner information (cabrio)
    By Ploki in forum Golf MK3 - 1993 - 1999
    Last Post: 04-02-2011, 11:47 PM
  3. Use of Air Conditioner
    By nm2003 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-06-2009, 08:14 PM
  4. Air conditioner
    By noshock65 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-11-2007, 10:45 PM
  5. Air conditioner, not cold, auto and econ indicator on
    By pluggy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-11-2007, 07:46 PM
