Thread: Rear Brake pads wearing on passenger side more than drivers.
  1. Rear Brake pads wearing on passenger side more than drivers.
    May 2015
    Birmingham
    6 Post(s)
    Hi all, Ive recently replaced my rear brakes pads with a new set of pagids, I noticed this time the passenger side pads were down to roughly 2-3mm material left whereas drivers side had at least 4-5mm material left. I Checked the slide pins which move freely and the caliper pushed back as it should so wasnt seized. I went for a test drive on some smooth roads and I noticed I could hear the passenger rear brakes sticking only a tad when stopped then setting off. The sort of sound when driving off while electric parking brake is on and it automatically lets go, but I only hear it for a split second so im thinking the caliper isnt letting go on the nearside as well as the offside rear. Any ideas what could be causing this eg do the electric motors need calibrating? Or should I do a full flush of the brake fluid, as I dont think its had a flush flush in years usually just replace the fluid in master cylinder every 2-3 years.
    Any ideas will be much appreciated!
  2. Re: Rear Brake pads wearing on passenger side more than drivers.
    Jul 2013
    76 Post(s)
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Rear Brake pads wearing on passenger side more than drivers.
    May 2015
    Birmingham
    6 Post(s)
    Thanks for that Dan, very interesting read I thought the electric brakes would be more complex to rebuild. Anyhow I shall bleed the system and check back in a few months, if that doesn’t work Il try rebuilding the calipers.
  4. Re: Rear Brake pads wearing on passenger side more than drivers.
    1840 Post(s)
    Servo problem due to water being drawn into the servo and making it rusty.
  1. New rear pads wearing out fast
    By MHDxMK5BK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-01-2018, 09:09 PM
  2. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  3. Please Help Rear Drivers side Passenger Door
    By worthingbloy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-01-2010, 05:20 PM
  4. rear tyres wearing badly on the one side...
    By lemmy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-10-2008, 07:54 PM
  5. locked rear drivers side passenger door
    By marcj in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2007, 07:51 PM
