Thread: Stinks of rich Exhaust fumes
Results 1 to 10 of 15
  1. Stinks of rich Exhaust fumes
    Nov 2017
    GB
    I have the 2.0 TDI 170 and I have found lots of people saying about it smelling inside and out of the car which does also
    Looking in to I don't think anybody has managed to resolve this issue completely.
    But I was just wondering what people have done to at least reduce it and what the most effective method was.
    Any info would be greatly appreciated!!
    Sent from my Pixel 2 using Tapatalk
  2. Re: Stinks of rich Exhaust fumes
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    you don't say what engine code it is or common rail / pd engine with or without DPF fitted, but a blocked dpf can give stinky exhaust, get the soot loading checked if it has dpf.
  3. Re: Stinks of rich Exhaust fumes
    Nov 2017
    GB
    Quote Originally Posted by Rob69 View Post
    Sorry it's a 2007 PD Engine code BMN. Not sure about the DPF, as I bought and soon after went away for work so don't have access to be able to check much on it. All info I have so far is just from the internet.
  4. Re: Stinks of rich Exhaust fumes
    1836 Post(s)
    The DPF has been removed and it has been mapped with the nasty tinterweb shared generic DPF delete map I have come across a number of times now on the BMN engine in all VAG group cars, the stink is so bad that standing behind one makes your eyes run. The only solution is a new DPF and a remap back to standard and most people I have quoted for this just reply, "I will sell the car". If the car is black it is probably the same A3 I have come across a few times now.
  5. Re: Stinks of rich Exhaust fumes
    Nov 2017
    GB
    It's not Black, I will have to have a closer look when I'm back home in December to see if the DPF has been deleted.
  6. Re: Stinks of rich Exhaust fumes
    1836 Post(s)
    Could be difficult to tell if the can has been carefully gutted.
  7. Re: Stinks of rich Exhaust fumes
    Nov 2017
    GB
    Is it easily accessible on these so I could disconnect the inlet and try and look inside?
  8. Re: Stinks of rich Exhaust fumes
    Nov 2017
    GB
    Also would a proper remap be able to sort it if the can has been gutted or will it need a new can as well?
  9. Re: Stinks of rich Exhaust fumes
    1836 Post(s)
    Even off the car it can be impossible to tell if the CAN is empty, we use an endoscope probe inspection camera through a sensor port. The only way we will put it right is a new genuine DPF (stupid money) and then we flash the ECU back to the current standard using the VAG online ODIS system.
  10. Re: Stinks of rich Exhaust fumes
    Nov 2017
    GB
    Yeah I been looking at the cost of new ones they are ridiculous. And even worse if it doesn't solve the problem!!
  1. exhaust fumes in car
    By arfs in forum Golf MK5 - 2004 - 2009
    Last Post: 08-01-2015, 10:33 AM
  2. Please Help Exhaust fumes
    By yydelilah in forum Golf MK4 - 1999 - 2004
    Last Post: 12-01-2011, 11:23 AM
  3. Question Exhaust fumes
    By RichKi in forum Audi A3 - Archive Topics
    Last Post: 24-11-2008, 05:34 PM
  4. Exhaust fumes in car
    By shottdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-07-2008, 12:34 PM
  5. Attention Exhaust Fumes ???????
    By belfastmark in forum Golf MK4 - 1999 - 2004
    Last Post: 02-07-2008, 03:21 PM
