Thread: Parking Sensor Control Module
  1. Parking Sensor Control Module
    Nov 2017
    Ireland
    Hi there,
    I've a mark 6 gt tdi and the parking sensor isn't working. every time i put it in reverse it gives off a solid beep for a few seconds. my mechanic plugged into the diagnostics and it came up saying Parking Sensor control module error.
    Trying to locate where this is. Have tried google, you tube etc with no luck.
    any help/ advice greatly appreciated!!
  2. Re: Parking Sensor Control Module
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Welcome to the forum.
    What error codes were coming back, you need to post them? If your mechanic has VAG-COM\VCDS he can check the system out.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  3. Re: Parking Sensor Control Module
    Nov 2017
    Ireland
    Hi there. Sorry I was up with mechanic today to ask and he said he plugged in his VAG COM/VCDS and it said parking sensor control module faulty. Thanks
  4. Re: Parking Sensor Control Module
    Feb 2018
    Ipswich, Suffolk
    Did you ever find out where park sensor control module is located on mk6 Golf?
  1. Parking Sensor Issue cant find module
    By chris27989 in forum VCDS - General Questions
    Last Post: 28-03-2016, 11:52 AM
  2. Audi a5 3.0 tdi parking sensor/module issue.
    By Siray11 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 15-02-2014, 11:51 PM
  3. Should I replace the parking sensor control unit myself?
    By noetus in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-02-2013, 06:17 PM
  4. Parking Sensor module upgrade
    By perparim in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-10-2012, 01:52 PM
  5. Question Parking control module part no.s
    By Adman in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2010, 09:57 PM
