Thread: Halogen headlight Upgrade
Results 1 to 8 of 8
  1. Halogen headlight Upgrade
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    Evening all,
    I have a 2012 Avant SE with the standard halogen reflector headlights fitted. The light output isn't brilliant, I've tried the nightbreakers and have some Philips lamps in at the moment. I have been contemplating fitting some LED headlight bulbs.
    Has anyone had any experience of them and do you think its worth it? Or should I put up with what I have until I change the car in couple years time.
    Thanks in advance
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  2. Re: Halogen headlight Upgrade
    Mar 2014
    Edinburgh
    235 Post(s)
    It’s like those hid kits out there. Light output is good and your visibility will improve but you will blind all oncoming traffic as the reflectors in the lens wasn’t designed for it.
    Not sure if they are road legal anymore and it will most likely trigger a a faulty light warning.
  3. Re: Halogen headlight Upgrade
    Feb 2016
    53 Post(s)
    Quote Originally Posted by A6S View Post
    I was hoping the LED's wouldn't glare as much as the HID kits would, otherwise I'd throw a set of them in. Apparently reading up on the LED's the bulbs focal point is same as halogen and differs from the HID bulbs which have the discharge tube in the wrong plane.
  4. Re: Halogen headlight Upgrade
    May 2012
    Everywhere
    308 Post(s)
    New out .
  5. Re: Halogen headlight Upgrade
    Mar 2014
    Edinburgh
    235 Post(s)
    LEDs bean pattern won’t be as round as a halogen bulb. It’s made up of multiple bulbs therefore there will be bright and dark spots. The reflector in the lens is looking for a round tube light which will give an even light all round.
    Might be better off fitting some higher wattage bulbs. The fuse and cables should take a 70w bulb. Just fitted a set of ring 130% on my dads car and they seem pretty good in the dark.
  6. Re: Halogen headlight Upgrade
    Feb 2016
    53 Post(s)
    Cheers lads, I will have a look about at other options, changing to Xenon headlights is out as even second-hand they fetching £300 a side without lamps or ballasts and wiring kit is a further £55
  7. Re: Halogen headlight Upgrade
    Mar 2014
    Edinburgh
    235 Post(s)
    Try getting a mot place to adjust your headlights. It could be pointing to the ground
  8. Re: Halogen headlight Upgrade
    Feb 2016
    53 Post(s)
    They are at the highest legal level, MOT tester told me that if im carrying anything in the boot I had to drop lights
  1. Halogen headlight adjustment MK3
    By meri_gadi in forum Leon
    Last Post: 03-12-2016, 02:31 AM
  2. halogen headlight adjustment for continental driving
    By lescroix in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-02-2014, 07:34 PM
  3. DIY: LED strip DRLs within halogen headlight housings
    By Scott Fitz in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-12-2013, 04:14 PM
  4. Question Headlight clusters - Halogen and HID - are they the same??
    By mjhamilton in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-08-2013, 10:17 AM
  5. B7 Halogen - Bi Xeneon or Xenon headlight how can you tell which you have
    By ihs61 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-11-2011, 09:52 AM
