Thread: Ecu box removal
  1. Ecu box removal
    Apr 2014
    Hi I have a Audi A4 b7 saloon I’m trying to remove my wiper linkage but can’t seem to get it out. Looks like I have to take the ecu box top and bottom out does any one have a clue how to do this. I have taken the top screws plus the bottom nuts off the box. There are wires going through the bottom half of the box that have three connection can I just unplug these or does the battery have to be disconnected any help would be great many thanks
  2. Re: Ecu box removal
    Oct 2017
    Kegums, Latvia
    Disconnect the battery and take the key out, that's at least what I did and had no problems afterwards.
    TIP: Unplug those connections and put something over that hole where wires go in so no crap falls in there. Then when you remove the lower part of box that's a good time to clean everything around there and underneath vacuum pump. Also check for that lower parts seal, may be a good time to replace it.
    Sent from my E5823 using Tapatalk
  3. Re: Ecu box removal
    Apr 2014
    Ok thanks for you help I will give it ago later many thanks
  1. Ignition barrel Removal (indicator arm removal)
    By paulw00 in forum Golf MK5 - 2004 - 2009
    Last Post: 27-02-2015, 08:11 PM
  2. Best pre-wash bug removal/film removal product
    By mikebeardmore in forum General Detailing/Cleaning Questions
    Last Post: 18-05-2014, 09:28 AM
  3. Hub removal
    By Tonyco in forum Polo - Derby - Lupo - Fox
    Last Post: 09-03-2012, 05:53 PM
  4. Front Headrest removal and seat back protector removal
    By brucelee in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-06-2009, 10:17 AM
  5. Ecu removal help ?
    By philglasgow in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-08-2007, 10:07 AM
